My 05 wrx did that found out boost controller was bad and wasnt getting proper air to fuel also had to get the ngk iridium cool plugs cause all others missfired hope this helps to test you boost controller only if you have stock one is to unhook the hose from it and take a SHORT drive and keep psi down be sure to reset your check engine light to see if thats a fix best of luck to ya
LinkBack URL
About LinkBacks
Isn't it odd that the previous owner had the flywheel installed for about 20k on it and had no misfire issues?
