Results 1 to 14 of 14
This is a discussion on uppipe install, one of the 3 mounting bolts for the turbo snapped off. advice needed. within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; so after getting my wrx back from the exhaust guy I had do the uppipe I noticed 1 of the ...
    Registered User Phobic's Avatar
    Aug 2012
    Boston, Ma
    so after getting my wrx back from the exhaust guy I had do the uppipe I noticed 1 of the 3 bolts for the uppipe didn't have a mount on the turbo. so I checked out some pictures and it seems that the longer area on the turbo mount broke off:
    in the picture it is the one away from the 2 closer bolts in the lower left. I will get a picture of it in my car in the morning pending rain.
    Im aware this is the shops fault and the shops problem, but what else other than get a new tubro can I do? anything?
    anyone know someone selling a stock turbo for a 02-03 wrx? :/
    Texas, United States
    Do you mean the stud for the downpipe? I believe the studs for the uppipe are installed on the uppipe not the turbo..
    Either way, you could use a stud extractor to remove the broken stud from the hole, then just tap a new stud into place. Inexpensive fix. I also have a stock turbo from my 02 WRX, but I'd probably want more for it than it's really worth.
    [EDIT]Never mind.. I see what you're saying, the flange on the turbine housing broke[EDIT]
    Aug 2012
    Boston, Ma
    yes, that's the term. the flange broke. its not broken close enough to the turbo to cause a leak, but Im guessing it will be a problem eventually.
    Im going to talk to the mechanic tomorrow and see what he can do for me. If I can find a used stock turbo and just get it rebuilt I'll jst install that and be done with it. I really don't want to go through a turbo upgrade right now. too much money I don't have.
    You could look for a trashed blown turbo and just pull the turbine housing. It's relatively easy to swap out turbine housings, I would imagine you could find a blown turbo for next to nothing.
    Aug 2012
    Boston, Ma
    good call. I'll try that, but most people probably wont be selling their blown turbos Id imagine. maybe something will pop up! thanks for the advice.
    Moderator Donkey's Avatar
    Da boonies
    I have a Tdo4 turbine housing. I could even port and ceramic coat it if you want. Pm me if you are interested.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Matt, that's normal. One of the studs from the UP bolts to a bracket on the block. Here's a pic from my 18G install:
    Facebook me here
    Registered User morgan46's Avatar
    Aug 2011
    Over The Rainbow
    Personally, I would just buy a new housing or a new turbo all together. td04s are very inexpensive, orrrrrrrrrrrrrrrrrrrr you might just have found an excuse to get a larger turbo!
    *My Headlights Turn Your Girlfriend On *
    http://www.clubwrx.net/forums/new-me...ml#post2135638
    -2002 Focus SVT-P.O.S.
    -1997 Subaru Legacy
    -2002 MBP WRX.. R.I.P.
    -2003 Sonic Yellow WRX!!
    Registered User xFalleNx's Avatar
    Nov 2010
    Moorestown, NJ
    ooooooor you could read Zach's post...
    --Anthony 2011 DGM WRX stg2+sf intake + custom front end deer mod!
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by morgan46 View Post
    I'm with zach. I don't think the turbo is broken. Just positioned differently than intuitively expected.
    It'd be pretty hard to break off a chunk of that turbine housing.
    2011 STi Build Log
    zax
    zax is offline
    Nov 2008
    Read my post.
    Sent from my DROID BIONIC using Tapatalk 2
    Facebook me here
    Well, he said "one of the three", so I'm assuming he's only got two bolt holes left on the housing.
    Aug 2012
    Boston, Ma
    Zach is correct, I was wrong. it looked like one of the flanges broke, but it is just that the mount wasn't put back on.
    Thanks a ton Zach. now I can stop worrying about it and just get that mount back on.
    WIN!
