In my opinion, never.
This is a discussion on FMIC, when are they needed? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Just as the title reads. When are they needed? I've been reading they are only needed when you have a ...
Just as the title reads. When are they needed? I've been reading they are only needed when you have a bigger turbo.
A car is only as good as its driver
Cody
Good news, everyone!
Facebook me here
Originally Posted by Mikie13
I understand the produced lag, but aren't the IATs cooler with a fm?
Facebook me here
Ohhhh ok you right.
I'm just seeing what mods to knock off my check list
People have run turbos as large as a 35r on TMIC with great success. I would say intended use is probably the biggest factor to consider. The main drawback of a TMIC is heatsoak.. so if you're building a dedicated drag car then FMIC may be a better option. For a daily driver a good TMIC is hard to beat.
I have a front mount because I like the way it cleans up the front of the car by filling the bumper gap and I think it cleans up the engine bay also.
2012 Limited Black Pearl WRX
My Build to Destruction
Isaac -- 2003 WRX sedan Stg II
He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
My mindset is anything that interferes with the bumper beam is not a good thing. If an FMIC fits without modifications that might compromise crash integrity, then it's just a matter of cost:
- Cost to buy the FMIC and piping
- Cost to figure out how to get everything fitted
- Cost to figure out what has to be moved and/or replaced (intake, dump valve, etc.)
- Cost to swallow to replace all the above when, not if, the car is crashed since the insurance company will pay for what was insured, not what isn't -- unless the owner declares the new parts etc. I suppose
If it's not there, it cannot fail, it cannot compromise the bumper, it cannot cost anything to replace.
I'll be getting a top mount because of those wonderful snow days![]()
Here is a good article to read:
ARE Cooling (Aluminium Radiators & Engineering P/L)
I you just want it for the looks,then buy any old kit. If you want it for performance then there is alittle more involved then just buying any old FMIC kit. The core size/core type,length/dia of charge tubes and your performance goals all come into play. And they don't all install the same either.
