Results 1 to 7 of 7
This is a discussion on 2008+ SPT Exhaust Review within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Finally got around to getting a video clip of my SPT CBE and put together a little before and after ...
    Registered User j6neal1's Avatar
    Apr 2012
    SE Virginia
    Finally got around to getting a video clip of my SPT CBE and put together a little before and after video. I know that there already is an SPT before and after video with a 2011 WRX hatch, but I did a full RPM cycle so you guys can hear it at every throttle level....enjoy!
    In 1080p if you have a screen that will support it (this is already posted in the Exhaust Sound Clips thread):
    I believe that this exhaust sounds great; pairing its tone with the ease of mind of not running into warranty issues, I don't think it gets any better. Granted, this setup is relatively expensive (mine was ~$850 after a 20% discount), but it is a perfect blend of the Boxer rumble noise that we all love and the daily driver ability that most of us need.
    I did want to address a couple of particulars about the exhaust as well. As many of you know, the flange that connects to the muffler to the main pipe (near the rear axle) sits significantly lower than the stock's bend. Here is a before and after of the clearnace that you will find with the SPT exhaust.
    Before (Lowest Point of Exhaust): ~7 inches
Name:	OEM Exhaust Ground Clearance.jpg
    Note that the lowest point of the exhaust falls almost exactly inline with the rear axle and, therefore, the tallest part of the wheel.
    After (Lowest Point of Exhaust): ~5inches
Name:	SPT Exhaust Ground Clearance.jpg
    Note that the lowest point of the exhaust has been shifted towards the rear of the car more and, therefore, does not have the added clearance benefit of the tallest part of the wheel.
    A simple example can be seen below. The green square represents an approximation of where the lowest point of the stock exhaust lies. The red square represents an approximation of where the lowest point of the SPT exhaust lies. You'll notice that the SPT exhaust actually has only about half of the clearance potential of the stock system.
Name:	OEM vs SPT Clearance.JPG
    Furthermore, I wanted to note the difference between where the tips "sit" on both setups with respect to the bumper. I did this to clear up a very common complaint about the SPT exhaust (that the SPT tips hang lower than the stock tips).
    Before (Distance between top of tips to bottom of exhaust cutout): ~1.75 inches
Name:	OEM Tip Clearance.jpg
    After (Distance between top of tips to bottom of exhaust cutout): ~1.5 inches (just barely over)
Name:	SPT Tip Clearance.jpg
    I did not modify the SPT exhaust in any way to "lift" it; this is how it came out of the Subaru shop although, if anyone still feels like it is excessively low, there is the quick "$5 Fix" to raise the tips floating around a Legacy forum. It can be found here:
    http://legacygt.com/forums/showthrea...r-162224.html?
    Well, that's all I have on the subject...hope it helps!
    Registered User xFalleNx's Avatar
    Nov 2010
    Moorestown, NJ
    Very nice info and pics!
    --Anthony 2011 DGM WRX stg2+sf intake + custom front end deer mod!
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Very nice review. Have you experienced any drone with the SPT exhaust?
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Apr 2012
    SE Virginia
    Quote Originally Posted by rage-wrx View Post
    I commute to work everyday (60mph highways) and experience no drone whatsoever. Honestly, the sound of the air rushing past the car significantly outweighs the exhaust notes. It's a perfect exhaust for my needs...growls hard on acceleration and tones WAY down at normal cruising speeds.
    I would definitely recommend.
    Jul 2012
    Hello guys, I saw this thread and would like to add that the spt is fairly quiet on the highway. My 2011 wrx hatch came with it from the dealer and the tire/wind/road noise is just as loud as the exhaust. its probably the quietest "aftermarket" exhaust out there.
    Registered User mista jc's Avatar
    May 2010
    Los Angeles
    Are any of you guys running stage 2 + SPT? My 08-10 dual SPT sounded great with my stage 2. It was quiet, yeah I agree, but when you get on it it's rather rumbly. Also, I let my friend drive my suby and he let me drive his s2k with the top dropped. As he blew by me the spt was rather loud and poppy, I was impressed. TOTALLY different than driving the car than being outside it.
    Apr 2012
    SE Virginia
    Quote Originally Posted by mista jc View Post
    I'm anxious to hear the newer SPT w/ stage 2 also. It looks like the road that I will be going down after my warranty is up...
    2012 WRX OBP Hatchback
