Bump
This is a discussion on Issue after walbro 255 install within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I put in the fp and 5 gallons of e85 and turned the key and I read no fuel level ...
I put in the fp and 5 gallons of e85 and turned the key and I read no fuel level and get no prime noise from the pump. Now my intake manifold is still off but I should at least get fuel level and prime noise even without it right? I already pulled the pump again and made sure all the connections were snug, and I checked my fuel pump fuse. ???
Bump
Fuel pump relay maybe?
Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
Do you know where that is located?
Uhhhh...I want to say it's on the passenger side on where the floor meets the sidewall. Right in front of the door. But don't quote me on that. I really doubt that it's the problem though. Are you running aftermarket fuel rails or the stockers? I think that once you put everything back together you should get what you need. The car may not be letting the pump prime because of parts you have removed.
Yeah I wont stress it too hard until my intake manifold and harness is all hooked up and back together. I will let you guys know if the problem continues when I get off and put it back together. Are you active duty or reserve btw?
When were you at Ft Riley? I have been here since 2007.
May-Jul 09
^^I was on my first deployment.
Ha, yeah he comes around here ALL the time.
*UPDATE* False alarm. You do infact have to have your IM/wiring harness all hooked up or you will get no response out of your FP/fuel level.
