Going to dealership for parts to install exhaust, what do I need?
Results 1 to 15 of 15
This is a discussion on Going to dealership for parts to install exhaust, what do I need? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So as the title says, I'm going to be going to a dealership in day or 2 to get what ...
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    So as the title says, I'm going to be going to a dealership in day or 2 to get what i need to install my nameless axleback when it comes. I was told i need new gaskets (someone mentioned OEM, others mentioned it may came with the exhausts?), new hangers? and most likely new bolts?
    Any help or advice would be greatly appreciated, can't wait to get these bad boys on!
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Quote Originally Posted by Mike193 View Post
    Don't go to dealership.
    The exhaust comes with all the necessary hardware. Reuse the stock bolts. You can reuse the stock hangers.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Registered User BPanda's Avatar
    May 2012
    NW Burbs Chicago and Central IL
    I emailed nameless performance a month ago or so and they said you can just reuse everything that's already on the car, unless you're planning to do some rallying then you'll have to change the hangers.
    2012 WRB WRX Sedan ...
    BPanda Build
    ...On order since 5/14/2012
    ...Picked up on 6/29/2012
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    I bought the urethane hangers from them when I was running the muffler delete from them. Jason said you can reuse the gaskets from the mid pipe so I did and no big deal. All worked fine
    Lead Wrench @ WTF Tuning, LLC
    Nov 2011
    North Jersey
    okay i'll be re-using everything then, but, I don't do rallying, although my friend has some property upstate, and all my other friends have big pickups, so we go up there with the quads and what not, and I can't help but do a few donuts on the wide open field they have (its flat as hell, it used to be a helli-pad)
    Are the eruthane hangers worth it? What differences will i notice? exhausts wouldnt wiggle as much, or it will be easier to install?
    May 2012
    I think they're just more reliable than the stock hangars. Pretty sure they're bigger and are just made of better material so they can take some abuse. Think about this too, the nameless performance axelback with muffler delete has to weigh less than the stock one with those huge mufflers. (not positive about this, but they are significantly smaller) So if the stock ones can hold up the stock muffler, then it shouldn't have any problem with the nameless performance.
    BPanda Build
    Aug 2010
    Yonkers/NYC
    The stock bushings are made of rubber. The aftermarket ones are made of polyurethane which are much more stiffer. They prevent you exhaust tips from moving about too much during very hard cornering & melting the bumper. Its a worthy investment.
    T0ny
    2011 WRX
    2012 FXT
    Nov 2011
    North Jersey
    I cannot find the aftermarket hangers on nameless performance site. Any other good companies?
    Aug 2010
    Yonkers/NYC
    They are the exhaust bushings at the bottom of the order screen 2011+ STi/WRX Sedan Quad Tip AxleBack Muffler Delete - Nameless Performance
    that or Accessories - Nameless Performance
    T0ny
    2011 WRX
    2012 FXT
    May 2012
    Yeah, it's the last choice when you're picking your options for the exhaust. Finish... Tip Style... Tip Location... The the Bushings, I don't think you'd need more than 2 if you wanted to go that route.
    BPanda Build
    Apr 2007
    8000' up in Colorado
    I wouldn't bother with any upgraded hangers for an axleback. They're a total waste of money, especially on such a new car where the stock ones are likely to be in like-new condition. I re-used the stock ones and the exhaust moves absolutely zero even on the track. I also wouldn't bother replacing any gaskets or bolts. I never recommend reusing gaskets except on just an axleback since that joint is the least critical one in the exhaust and it's probably not going to leak if you properly torque things.
    Scott
    Nov 2011
    North Jersey
    So I went to order my exhausts last night, but I clearly needed to do a tad bit more research. There are option such as, 3 inch, or 3.5 (I'm guessing this is the width of the exhaust pipes. So theres my first question, what are the results of both the 3 inch and the 3.5?
    2. It has a choice of staggered or non staggered. I'm guessing that means if the exhausts are equal on each side, or one is set back. I believe I want them to be equal.
    3. It asks if I want single wall or double wall. No idea what that means, I'm guessing it slightly changes the tone of the exhausts?
    I'm trying to re-order by tonight so help is greatly appreciated!
    May 2012
    Staggered just means the exhaust tips won't line up, one will be farther back than the other (my personal choice). Just take a look at the pics, it's a pretty big difference between the two. I'm sticking to a 3" exhaust, I'm not planning on doing a ton of work to the car, so there is no reason to get a bigger exhaust. To be honest, with the single or double wall, I'm not positive what it means, but I think I'd rather have a double wall than a single, and if you're going with the 3", a single wall isn't even an option. The second my car comes in, it's the first thing I'm ordering. I'm going to keep all the options the same as when you first go to the page with the muffler. I'm doing the muffler delete too, I want that rumble.
    BPanda Build
    Registered User Brian Najarian's Avatar
    Dec 2011
    Miami
    I also ordered my nameless axleback exhaust last thursday, and getting the 3.5 brings the price up like 50$ or so ( idr ) i dont think its worth it, but thats just me. and i also read somewhere else that none of the options effect the sound of the exhaust
    Aug 2012
    Alexandria, VA
    Duh! The options are straight cut or staggered exhaust tips, the staggered gives the rear a more rounded line as the rear of our cars have a slight curve to them. The inside tips are longer than the outside tips (see pictures on their site). The 3" or 3.5" is not the pipe size but the exhaust tip size; the smaller 3" is like similar to the stock sizing. Single or double wall again refers to the tips only. Single being like the stock ones and the double adding more rounded thicker appearance of the tips.
