where did u get the stage 3 map?
also ur no longer fmic? your IPR tmic?
im almost same set up with you but i have tomei uel header and process west tmic and forge bpv
im making close to your power but on 91 oct and 19.6 psi
This is a discussion on IPR TMIC Intercooler within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by KronosPerformance I'm sorry but what the heck is a virtual dyno? Its a free software that can ...
Its a free software that can calculate your hp from data logs Virtual Dyno
311WHP 352 TORQUE @19 PSI 93
K&N typhoon intake, Turboxs bypass valve
IPR TMIC, Invidia Q300 Exhaust
3" Tsudo Stainless Bellmouth Downpipe
GrimmSpeed Electric Boost Solenoid
http://youtu.be/dhzZrictLAk
I got the map from Eric @ TP
Now Im running FMIC, the IRP is worst than the stock IC. 311HP was with the IRP IC and after I install the FMIC with Eric's map the car is a lot faster. Also I ported the turbo because I was getting boost creep and did some adjustments to the map. Make sure U got AFR Gage. Good luck![]()
