2.5l hybrid
Results 1 to 15 of 16
This is a discussion on 2.5l hybrid within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; im looking to do a 2.5l hybrid swap in late december. just curious on what i would need electrically to ...
    Registered User tylerbryant's Avatar
    Apr 2011
    kent, Wa
    2.5l hybrid
    im looking to do a 2.5l hybrid swap in late december. just curious on what i would need electrically to complete the swap, and any places where i can buy the parts needed. im in washington in the seattle area and im going to need a pro tune can anybody recommend a garage for a tune and the swap?
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    world one
    Lead Wrench @ WTF Tuning, LLC
    Maxwell Power Services
    Sent from my Droid using Tapatalk
    Resident Tuner @ WTF Tuning
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by tylerbryant View Post
    Nothing.It's a straight drop in.
    2002 FORESTER S
    1998 FORESTER S
            MainFrame's Avatar
    Austin, TX
    ^this
    and you'll need a tune
    Apr 2011
    kent, Wa
    i don't need a 2.5 ecu the 2.0 ecu will work?
    Jul 2010
    Cincinnati
    As long as you're keeping the 2.0 heads, all of the 2.0 wiring and ECU will work
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Apr 2011
    kent, Wa
    ok i was planning on rebuilding the heads as well or at least new valves.what injectors should i use? any turbo suggestions?
    Budget? Power goals?
    Apr 2011
    kent, Wa
    my budget is about 3400 idk about power i just want a car i can go fast if i want to
    What's already done to the car?
    Apr 2011
    kent, Wa
    brand new 02 trans. tbe. COBB tuner. manual boost contoller.
    A hybrid build is not really in the cards for you (especially if you're paying labor for anything other than tuning). You'll want a new EJ25X motor with minimum forged pistons, gasket set, water pump, oil pump, etc.
    $3400 will pretty much cover that, and a hybrid with the TD04 is not a good match; you want at least an 18G, and that will up your budget quite a bit to do properly...
    Up your budget or change your goals.
    Apr 2011
    kent, Wa
    can you post a link on where to find the ej25x?
            MainFrame's Avatar
    Austin, TX
    That's the whole point of a hybrid swap. All you're changing is the shortblock, so all of the electronics and everything associated stays the same.
    And $3400 isn't going to get you a hybrid swap completed. With all the parts associated (oil pump, water pump, pulleys, tensoner, gaskets, of course forged pistons, etc., not to mention the block itself) then the labor costs.. you're looking to pay ~$1200 just to have the engine removed from the car and replaced when it's all done. If you want to do this and do it right you will need to at least double your budget. My hybrid build easily surpassed the $10k mark without even blinking an eye.
