jerking at 5000 rpm
Results 1 to 14 of 14
This is a discussion on jerking at 5000 rpm within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; hey guys so i have 04 wrx 70000 miles only mod is an intake, this problem developed recently, if i ...
    Registered User kornkid21792's Avatar
    Jul 2011
    billings mt
    jerking at 5000 rpm
    hey guys so i have 04 wrx 70000 miles only mod is an intake, this problem developed recently, if i drive part throttle over 5000 rpm its fine,but if i full throttle it once it gets to 5000 the car jerks and wont go any further,i push in the clutch and its fine again, can cruise normally but then again if punch it it just jerks and wont go past 5000 rpm again, i tried to do searching saw some threads saying the ecu tune from subaru sucks?any ideas guys thanks in advance
    Palmyra, NJ
    04 WRX tunes aren't really known for being bad.
    Sounds like your clutch is slipping.
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Could be your boost controller solenoid to be honest. If it was a slipping clutch, you would be revving fast and accelerating oddly.
    Jul 2010
    Cincinnati
    Maybe boost cut? Just a thought
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Jul 2011
    billings mt
    why,would it boost,cut im only showing ten pounds at full throttle
    Aug 2009
    Canada/Ethiopia/Madagascar
    Is your CEL functional? i.e. do you see it light up briefly when you turn the key to the on position? You're not experiencing fuel cut because of over boost if you're only seeing 10 psi (assuming your gauge is accurate), but based on what you've said so far I'd guess it's fuel cut...for some reason.
    Do you know anyone with a Tactrix cable so you can get a Learning View?
    ...Rob.
    Jul 2011
    billings mt
    thanks again for all your replies i am so thankfull, you guys are much better then the honda crowd.ok so drove around about 40 miles after resetting the ecu, and a solid cel light came on so ill go get a code reader in about a hour and pull the code with a code reader,sadly i am in mt and we have utterly no tuners out here sucks alot,i think its deff fuel cut. engine is fine just driving normal wich makes me feel better,sorry if i sound stupid this my first subie and first turboed engine,
    Moderator Donkey's Avatar
    Da boonies,Va
    List your mods. What was the code? Just because there is no tuner close by doesn't mean you can't get the proper Engine Management. You can easily use the Cobb Accessport or a Laptop with a Tactrix cable to flash a map to the car.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2011
    billings mt
    so you think engine managment is the problem? only mod is a sri and the code was p0302 missfire cylinder 2
    Da boonies,Va
    You mentioned not having a tuner near by. Thats why I mentioned about the engine management. IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!! What intake do you have? Are you using 91 octane or higher?
    2002 FORESTER S
    1998 FORESTER S
    Jul 2011
    billings mt
    thank you i did read that seems like most of that stuff id have to take a to a shop for
    i am using a spectre intake with spectre filter, i was using 93 then switched to 91 to see if that made a differnce with no success always using premium gas though
    Da boonies,Va
    The Spectre intake is junk and should be taken off. It is a 3" ID and the stock ID is 2.8".
    http://www.cobbtuning.com/info/?ID=3223
    2002 FORESTER S
    1998 FORESTER S
    Aug 2009
    CobbTuning.com - Aftermarket Intakes
    Wow, ~13% difference in area. Scary; goes a long way towards explaining the misfires.
    OP, how long did you have the intake on before the problems arose?
    ...Rob.
    Jul 2011
    billings mt
    i also now have p0137
    intakes been on for a very long time before problems arose
