Racing fuel: tune necessary/available?
Results 1 to 15 of 16
This is a discussion on Racing fuel: tune necessary/available? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey y'all. I have a 2011. The Sunoco near my house sells 110 octane racing fuel and I want to ...
    May 2011
    South Florida
    Hey y'all.
    I have a 2011. The Sunoco near my house sells 110 octane racing fuel and I want to see how the car runs on it. Should I be concerned about fueling a stock tuned car with 110? Do I need a tune?
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Yes...you would need a tune to take advantage of any high octane fuel like that.
    It may even cause negative affects if you do it without.
    May 2011
    South Florida
    Thanks for responding.
    Nov 2005
    Princeton, NJ
    Quote Originally Posted by Vroom! View Post
    Anytime.
    Registered User jgardiner's Avatar
    Oct 2010
    Calgary, Canada
    You can use that fuel but unless you tune for it there won't be any advantage, just extra cost.
    May 2011
    Jersey
    Is that something COBB would be able to help out with ? Im in the same boat, access to high octane but cant really use it....
    ---Joe---
    May 2011
    Jersey
    .....or bigger injectors and E85 too, whats the deal ?
    ---Joe---
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Oh! Snap! View Post
    ---Joe---
    You need to tune for the fuel you are using, simple as that.
    May 2011
    Jersey
    I get that, but is that something that COBB and I will be able to do ? Can that MAP be added to my AP ?
    Thanks
    ---Joe--
    Jan 2005
    Eh, whaaaaa?
    This.
    Fuel is a very important part of engine tuning. Too high octane without any tuning is going to either give you no gain what so ever, or as mentioned above, even power loss. Too low octane is going to cause detonation and possibly engine damage. Essentially your ECU needs to know how to handle what's been done to it. If you don't tell it what to do, it's going to act like nothings changed and that can have very negative consequences.
    Always do your research on the mods you want to use on your vehicle before even purchasing the mods. I'd recommend anyone new consulting a professional tuner in their area.
    Cody
    Nov 2005
    Princeton, NJ
    ---Joe---
    I think some people make too big of a deal with higher octane.
    High Octane has a higher resistance to detonation, so there would be 2 main purposes of using it...one would be if you are requiring it due to if you go to a lower octane you would produce knock. The other reason is if you are trying to improve power. The only real way to gain power from higher octane would be manipulating ignition timing and possibly running a little leaner. Depending on your setup though, doing this would result into minimal power increases and is something that should be done on a dyno to actual measure your powerband, whether its increasing or not. Just because you advance timing doesn't mean that you will automatically make power or that its making power safely.
    Cliff Notes: If you have a basic street setup, this is no real necessity or major power increases from higher rated octane fuel after tuning. Note, when I say major, I'm saying you're not going to jump 25-50 HP just from changing the ignition timing on a basic street setup.
    May 2011
    Jersey
    10-4.
            MainFrame's Avatar
    Austin, TX
    Thanks
    ---Joe--
    Yes, if you take your car to them for a dyno tune they can get you set up on e85 with ease. And loading the new map on your AP is a cinch.
    Quote Originally Posted by KronosPerformance View Post
    Depends on what fuel you're talking about. It isn't unheard of to see gains of +50whp and +70ft/lbs when switching to e85. There are several stage two STis out there pushing 400ft/lbs at the wheels running e85 on a stock turbo. I would consider that significant gains. Although there's more benefit to e85 than just higher octane.
    May 2011
    Jersey
    Thats what Im looking for, thanks.
    ---Joe---
    Nov 2005
    Princeton, NJ
    Yeah I specifically didn't mention E85 lol
