Page 1 of 12 1234567891011 ... LastLast
Results 1 to 15 of 173
This is a discussion on Fuel pump, injectors, TGV deletes and TD04 19T within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; The deletes will arrive next week. I'm on the fence about a mild turbo upgrade (TD04 w/ 19T wheel). Should ...
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    I'm on the fence about a mild turbo upgrade (TD04 w/ 19T wheel). Should I?
    7/14: I did.
    Arrived 7/7:
    7/14:
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    ClubWRX.net Vendor KronosPerformance's Avatar
    Nov 2005
    Bordentown, NJ
    Nice!
    What are your plans ultimately power wise?
    ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
    AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
    [/SIZE]
    USE COUPON CODE FIRST5%OFF to receive a discount of your first order
    Kronos has Special Pricings on Process West & Agency Power!
    CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Do it....do it.
    Greg
    www.modmeets.com
    ProTuned Stage 3 '11 WRX Ltd HB (SWP) ~ 342 awhp 399 ft-lb tq on E85
    Mods Blog Post
    Friends don't let friends drive Mitsubishis.
    Apr 2004
    Southeastern PA
    Quote Originally Posted by KronosPerformance View Post
    Nice!
    I'm pretty much there now - check out my Mods & Pics link in my sig.
    The turbo side TGV sensor has been intermittently throwing CELs since I did a Deadbolt Monster TD04 turbo swap 3 years ago. Access to that sensor is all but impossible without removing the intake manifold. Adding the deletes will take care of that. The stock injectors are at the ragged maximum when the weather gets cold, so in go the injectors and pump. Access to the turbo will be far easier with the manifold off ... to 19T or not to 19T?
    Mods & Pics
    Registered User c2bcoolwrx's Avatar
    Mar 2008
    SFLA
    IMHO it is really not worth it to put any more money into the TD04. It really is just too small. I would look into a used 16G down the road, good ones are usually available. I think a regular 16G or an EVO3 16G would do you wonders.
    Apr 2004
    Southeastern PA
    Quote Originally Posted by c2bcoolwrx View Post
    I love the fast spool and low rpm torque I have now - don't want to give up much of it. 20 psi @ ~3000 rpm is fun.
    Mods & Pics
    Mar 2008
    SFLA
    Quote Originally Posted by Sasquatch View Post
    That statement is kind of misleading, or just not the whole story.
    Think of it this way 20PSI at 3000rpm from a TD04 vs. 16-18 PSI from a 16G at 3000rpm. Even though the 16G will not be at target boost (running less PSI) at 3000 the 16G still will be pushing more air/CFM and making more power than a TD04. People get way too concerned with lag, with the right sized turbo and mods the extra CFM a larger turbo/16G puts out will easily make more power and negate any extra lag over the TD04. The TD04 is just too small and really limits you.
    I remember when my 2.0L block went and I went hybrid I was debating whether to stay w/the TD04 or go EVO3 16G. In the end I went with a Blouch TD05-18G 8cm. Lag for me is a non issue and hit peak boost of 19PSI by 3200rpm. Yes, a TD04 would hit peak earlier but it would not make near as much power at the same RPM and die off around the 6,000RPM mark. While my 18G keeps pushing hard all the way to my 7500RPM Redline. I realize you are running the EJ205/2.0L, but my experience still applies.
    Jul 2010
    Cincinnati
    I've heard this statement more than once and I don't understand. Pressure is pressure, it doesn't matter what is pressurizing the intake. It takes x amount of volume of air to make y amount of pressure in a given space so how does it matter what is compressing the air? Given, the larger turbo has the ability to move more air, but if its building the same pressure in the same space at the same engine speed, it's not moving any more air. If I am wrong please explain...
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Mt. Laurel, NJ
    Maybe it comes down to the amount of air it moves during a given amount of time...
    All I have to say there has to be some merit to it because my VF43 boosting at 21psi was incredibly slower and less powerful than my buddy's 20g boosting at 21psi...
    But Bill, the way I see it...if you have the fuel upgrades, you already have the prereqs to upgrade the turbo. May as well make use of it so long as you have the means to. The 19T or a 16G both seem like viable options. Ask what your tuner may suggest as well because I don't need to tell you that a good protune will be necessary.
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    it's cooler.
    But you're right - at a FIXED rpm, pressure = pressure. The difference comes in the top end.
    Sasquatch: I think you'd be happy with a 16g, or a vf34 or similar... or even better - go nuts, go equal length manifold, and throw on a vf36!
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Are you still running SCCA events? Look closely at the existing rules for the class you are in and try to get an idea of what changes people might have in mind. If you go every other weekend so to speak you may not like where a turbo will land you, or it may change your schedule (first class, last class, get up earlier, leave later etc.) so consider that.
    See if you can figure out what new cars are coming out and where they might be classed, it might give you an idea of what's in store for your existing or new-turbo-upgrade class. The newsletters are decent info sources too, especially the correspondence since people ask questions like this all the time.
    I'm with c2b on this one; throwing any more $ at the TD04 is a waste to me.
    What injectors did you get?
    Mt. Laurel, NJ
    My guess is 650cc's based on the 6, 5, and 0 in the part number
    Google also provides pretty good results
    Jul 2010
    Cincinnati
    I agree with you, I'd rather have less peak power but more down low than the opposite. I don't race enough to need all my power at 6k RPM.
    Stink eye mob #727
    Mar 2008
    SFLA
    Quote Originally Posted by jd92677 View Post
    You are wrong. Just b/c a turbo is running at the same PSI does not mean it is pushing the same amount of air/cfm. A smaller turbo at a higher PSI can easily be outflowed by a larger turbo at a lower PSI. Thus, even though a Tdo4 will hit 21PSI at 3k and a 16G will be at ~18PSI at 3k the 16g will outflow the Tdo4 and make more power.
    So even though the larger turbo will take longer to hit XX PSI it will still make more power at a lower PSI at the same RPM. Of course this is for a reasonably larger turbo and would not apply if your were to compare a TD04 to 30r, b/c of course a 30r will have a lot of lag and feel like crap at the lower Rpms b/c it is too big of a turbo for a 2.0/autox.
