Fuel pump, injectors, TGV deletes and TD04 19T - Page 5
Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 61 to 75 of 174
This is a discussion on Fuel pump, injectors, TGV deletes and TD04 19T within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by metaldahlberg I assume that would come from tuning the valve timing. nono, I'm talking, you have a ...
  1. #61
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    Quote Originally Posted by metaldahlberg View Post
    nono, I'm talking, you have a small turbo, you swap out for a big turbo, what about being able to flow more air out the turbo makes your engine want to take in more air? This is the link I can't visualize in my head...
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
  3. #62
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by poly_poly-man View Post
    I get that the greater the volume (well, really mass, but for the sake of the CFM comparison) of air you push into an engine, the more power. I'm just wondering HOW, with the same pressure, you can get more air to go in?
    Because that pressure is not static. It's dynamic. You keep using the examples of sealed enclosures and thats not what engine are as a whole. They are big air pumps,just like turbos are.
    2002 FORESTER S
    1998 FORESTER S
  4. #63
    Feb 2010
    True, but if you visualize the turbo as a pump, you're pushing air into the engine through a fixed nozzle. No matter how much flow the pump is rated for, with a certain pressure at the nozzle, you'll get the same amount out (into the engine, in this case). Now, I get that the engine itself is also working as a pump, sucking some air in too. However, for a fixed RPM (or piston velocity), how can this side of things be any different?
  6. #64
    Da boonies,Va
    VE. Just how changes to cams or valve size can change VE so can turbos. It's all about CFM. Bigger turbos have more of it and can move it faster if the engine will injest it. Not to mention bigger turbos do it at a lower intake temperature,which equals denser air. Bigger turbos also do it at a lower rpm. Hence why you can't run 20psi-redline on a Tdo4 but I can run probably 23-24psi to redline on my 16G-XT.
    2002 FORESTER S
    1998 FORESTER S
  7. #65
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    exactly. My question is.... HOW? How does the engine take in more air???
    I'm not trying to argue - I'm just really confused
    The 4 cycle engine consists of ignition near TDC (top dead center), the stroke going downwards to push the crank rod, then the piston traveling upwards to expel the exhaust gasses, then downwards to allow the air/fuel mixture to go into the engine, then compression and the next boom.
    As the piston travels downwards it creates a vacuum (hence the VAC at idle). It sucks in as much air as it can. The turbo helps to push more air into the engine. The resistance between the turbo and the ignition chamber, and the CFM of the turbo at that given PSI both determine how much air is injected into the cylinder. There is no "static pressure". The engine is always sucking, and the turbo blowing.
    (if you're a visual person... here's a link to the Otto cycle) Animated Engines, Four Stroke
    One thing I think you're also forgetting... the PSI in the intake tract is measured at the turbo outlet... not in the heads. Resistance, flow, and heat will always change that number by the time you get past the valves. A more efficient turbo will always have less resistance more flow and less heat when it's in it's "sweet spot"... like Donkey is talking about with his 16g-xt vs a TD04.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  8. #66
    Feb 2010
    I think this is the key point I'm missing...
    ...so now my question - why don't they :P
  9. #67
    Apr 2004
    Southeastern PA
    Quote Originally Posted by T0rque View Post
    sorry sir... just my opinion tho..
    No need to be sorry ... should have added a
    This is probably the most threadjacked thread I have ever posted, but it is quite OK. The flow of info is quite useful / entertaining.
    Mods & Pics
  10. #68
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    Maybe it would be beneficial to split the thread in 2?
  11. #69
    May 2010
    Pittsburgh, PA
    Buy the XT. If you don't... You'll be driving it for years thinking, "Ugh, I should have just spent the $255 years ago and enjoyed it since."
    It's not a perfect thought train, but has it's merits
    2011 STi Build Log
  12. #70
    Apr 2004
    Southeastern PA
    I just spoke with Blouch in great detail about the three contenders for my turbo swap. The winner is ...
    The 19T upgrade. Unless I radically change the way I drive the WRX it really is the best choice. I have had the WRX for over 7 years now and know what I want out of it.
    Both 16Gs will have way more top end that I will really ever use or need. I'm told the non-XT 16G starts to spool up at 3500 to 3900 rpm. I know I will not be happy with that. The XT will be even worse. Yes, I know I will have the fuel capacity for a lot more turbo. I'd also like to keep my stock internals intact for a while.
    I was told the maximum flow rate is 480 cfm for the 19T and the 16G would be 510 - 515. Those figures are right from the builder of both turbos.
    There is this discussion as well that seems to indicate great things about the 19T: TD04 19T Upgrade Discussion - NASIOC
    Mods & Pics
  13. #71
    May 2010
    Pittsburgh, PA
    Haven't read much about the 19T. I'm sure it'll be a nice boost compared to the stock one though =). Let us know your impressions of it.
    2011 STi Build Log
  14. #72
    Da boonies,Va
    Quote Originally Posted by Sasquatch View Post
    I'm just curious what they are referencing too. My 16G-XT in third gear will hit 20+psi by around 3600-3700rpm. A normal 16G can do that around 3200-3300rpm. 19T will still be a fun turbo!
    2002 FORESTER S
    1998 FORESTER S
  15. #73
    Feb 2010
    I've seen decent things about the 19T - it's a good medium on the MHI side...
    ...but why the hell aren't you getting an IHI turbo???
  16. #74
    Registered Whippersnapper mustangtx63's Avatar
    Mar 2005
    How many miles are you at on the WRX, Bill?
    ~ Retired Blobeye Syndicate #063 ~
    2011 Ford F-150 ECOBOOST 4x4
  17. #75
    Apr 2004
    Southeastern PA
    Quote Originally Posted by mustangtx63 View Post
    I'll probably have just passed 60k miles at the time of the install.
    Arrived today. They are purdy ...
    Mods & Pics
