Fuel pump, injectors, TGV deletes and TD04 19T - Page 10
Page 10 of 12 FirstFirst 123456789101112 LastLast
Results 136 to 150 of 174
This is a discussion on Fuel pump, injectors, TGV deletes and TD04 19T within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; The WRX is now running much more smoothly with no CELs. While there is still more tune tweaking to be ...
  1. #136
    Apr 2004
    Southeastern PA
    First tuning session
    The WRX is now running much more smoothly with no CELs. While there is still more tune tweaking to be done, the initial results are promising.
    I may have lost 100 - 200 rpms of spool, but the upper end of the powerband seems radically transformed. I am not used to seeing the tach climb as fast as it now does. It will take some time to evaluate the the overall feel as the tune improves.
    Once the tune gets dialed closer to the ideals the spool up may yet increase. I'm still going over the logs along with my tuner. There is now ample headroom for the injectors.
    Mods & Pics
  3. #137
    Registered User mexicanzero's Avatar
    Oct 2009
    Ottawa Ontario Canada
    get your tuner to do a virtual dyno next time, not for #'s but to see the powerband
    and 1-200rpm is a small price to pay for the improvements!
    LIVE LOUD, ROCK HARD!!@
    2003 WRX wagon 16g + 6 speed
  4. #138
    Apr 2004
    Southeastern PA
    Quote Originally Posted by mexicanzero View Post
    A virtual dyno was mentioned and is a possibility. My tuner is guesstimating 280 awhp may be the new number (246 was the old).
    I will likely do some real dyno pulls when the weather cools down for more accurate comparisons to the previous mod lists. The 3 pulls I had were done at 60 - 70 degrees F.
    Mods & Pics
  6. #139
    Aug 2009
    Canada/Ethiopia/Madagascar
    If you did loose that small amount of spool I'm sure the volume of air you're moving is more than making up for it. Should be a nice daily driver power band. I've been having a harder time resisting a turbo upgrade lately, if I was 2.0 I'd be all over the 19T upgrade.
    ...Rob.
  7. #140
    Apr 2004
    Southeastern PA
    Quote Originally Posted by mudferret View Post
    This is only day one - so far I like what I see. The tach rises fast, I then look over at the speedo and see serious numbers. It was rather hot out today - I can only imagine what will be with a tweaked tune and cooler weather.
    Mods & Pics
  8. #141
    Palmyra, NJ
    Great to hear Bill! Next Victory Meet looks promising then
  9. #142
    Apr 2004
    Southeastern PA
    I am ready now. CF 2011 not so much.
    Mods & Pics
  10. #143
    Palmyra, NJ
    Quote Originally Posted by Sasquatch View Post
    Yeah I was bummed about that. I planned to go months ago...even told my boss. Couple weeks ago, he forgot and we had a big upgrade scheduled.
    At least I'll have my BBS's and a half decent un-mangled door for this Victory meet...and I'll be bringing the girl I'm seeing. She loves cars, and beer
  11. #144
    Apr 2004
    Southeastern PA
    Topless pics or it never happened ...
    Mods & Pics
  12. #145
    Registered Whippersnapper mustangtx63's Avatar
    Mar 2005
    This. Please post in the I heart bewbies thread. thx
    ~ Retired Blobeye Syndicate #063 ~
    2011 Ford F-150 ECOBOOST 4x4
  13. #146
    Boost > NA itWRXjustfine's Avatar
    Aug 2009
    Fort Riley
    Man, great read. I am way stoked about your progress!
    2004 Impreza Outback Sport - Sold
    2004 WRB WRX - Sold
    2006 SGM WRX - 400AWHP - Mods
    My 2006 Build
  14. #147
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    bump for update?
    (what'd you end up doing with the phenolics?)
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  15. #148
    Apr 2004
    Southeastern PA
    bump for update?
    Once the intake was off and I saw what was left to do for the reinstall I just got an uneasy feeling about the spacers. The pins in the heads would not help with the realignment and I was also unsure about how an extra 4mm of intake height would affect how everything would reassemble.
    I had the second intake gasket and spacers in their original unopened packages. GrimmSpeed gave me a full refund. Having sent the OEM TGV bodies back for the $140 core value, the gaskets and spacers went along for the ride.
    With the weather cooling off and a few revisions of the tune in now place the upgrades provided a definite noticeable bump in performance. There is still a bit of tune tweaking to be done and some dyno time is a probability within a month.
    100 - 300 rpms of fast spool have been lost. Thought I would really miss it, but it was a simple matter of shifting at different times. The increase in the top end has more than made up for this. The maximum amount of boost is about the same as before - it just does not drop off as fast. I now have ~3 psi more boost near redline - a very noticeable difference.
    Without having installed a TD05 20G to compare with, I'd say the TD04 19T did all I'd expected of it and then some. The 650cc injectors are pushed to < 80% duty cycle. Plenty of headroom for the cold weather coming.
    There is popping and mini-backfiring I did not have before the swap. I'm hoping this is mostly due to the TGV deletes and the way the fuel is able to flow more freely. It is possible the tune is still a tad rich.
    Mods & Pics
  16. #149
    Palmyra, NJ
    Popping and after-fire makes it sound fast
    Flames shooting out of the exhaust make it look faster
  17. #150
    Apr 2004
    Southeastern PA
    A slight downside to the TGV deletes: it has gotten down to the lower - mid 40s in the early morning. The idle at start up has been affected. It has become somewhat unsteady for a minute or so, but quickly smooths out. I'm wondering what this might be like when the temps are near zero. :/
    It does sound kind of cool ...
    My neighbor installed a "flame thrower" system on his 1991 Mustang project car. Meh.
    Mods & Pics
