AEM vs. Cobb intake system questions
Page 1 of 7 1234567 LastLast
Results 1 to 15 of 99
This is a discussion on AEM vs. Cobb intake system questions within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey guys, as some of you know I got my wrx about 2 months ago at this point and this ...
    Registered User skudda33's Avatar
    Apr 2011
    Morris County, NJ
    Hey guys, as some of you know I got my wrx about 2 months ago at this point and this is my first car that i have wanted to add mods to and what not. I am ordering a cobb accessport and have been looking a different intakes and ram into a question about the two systems mentioned in the title. I know the aem mounts in the fender wall and there is the slight possibility of it sucking in water but that is very rare i heard and should not be a concern. The cobb system seems to mount in the stock air box or i could purchase the whole system with the airbox included. My question is, is the cobb worth buying with the airbox also or will it still function properly in the stock box if that is possible. Also anyone know if one system is better then the other when it comes to sound, performance, etc. ANy help would be great and if something i have stated is not clear let me know haha. Thanks!
    Dec 2010
    Fountain Valley/Irvine, CA
    I think the airbox is worth buying cause it'll keep the heat coming from the engine bay near the filter and the filter will get fresh cold air using the stock airdam which isn't really useful w/o the box.
    Also because the cobb SF is a short ram, it'll be louder than the aem intake. performance wise everyones been saying there's no difference between the two so go with what you would rather have. if you get a lot of rain then cobb so you don't have to worry bout hydrolock, if you want cold air consistently and never have to worry bout heat soak then aem.
    i had a aem cold air on my old civic si. it performed flawlessly and the dry flow filter was much easier to clean than a oiled filter(cobb sf) but on my 2011 i chose the cobb over aem cause of the airbox and to try something new.
    Jul 2010
    Cincinnati
    CAI > SRI, go with AEM. The cooler the intake air, the better.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Apr 2011
    Morris County, NJ
    Quote Originally Posted by jd92677 View Post
    Even with the risk of hydrolock? or does everyone just overplay this risk and make it seem much worse then it actually is?
    what setup do you have on your car?
    Quote Originally Posted by skudda33
    If you drive through a puddle deep enough to hydrolock your motor, you're a moron and deserve it.
    Resident Tuner @ WTF Tuning
    Registered User Admiral AGbar's Avatar
    Apr 2011
    Houston, TX
    ^ this
    Sent from my PC36100 using Tapatalk
    Apr 2011
    Morris County, NJ
    Fair enough haha I was just going off what I had read and heard about the cai's. I don't plan on submerging my car ever so I shouldn't have a problem then lol. I was just curious to see if there really was ab issue with that at all. Thanks for the input!
    Jul 2010
    Cincinnati
    Quote Originally Posted by skudda33 View Post
    Right now I'm just opensource stage 1, plus some bushings and mounts. Still puting together a plan for my next upgrades.
    Stink eye mob #727
    There are splash guards for a reason. In order to ingest enough water to cause an issue, you'll have to drive through a puddle that's over a foot deep.
    Jun 2011
    Vermont
    I have a perrin cold air intake and I'm very happy with the performance and sound difference it has made.
    Apr 2011
    Morris County, NJ
    Quote Originally Posted by iWRXu09 View Post
    I do not think cobb has a perrin map do they?
    Dec 2010
    cobb doesn't but perrin does. they made a custom map you can load onto your AP to flash the car with. They email it to you or something when you buy the perrin intake
    U.S. Combat Veteran (3ID) Stu_Gotti's Avatar
    Jan 2011
    Southern Maryland
    ROFL!
    My Build : IAG Closed Deck Stage 2.5 ~ 427hp/399tq | Facebook | I may appear calm, but in my head I've killed you three times
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Everyone overplays it. You would literally have to have your filter submerged in water for a long period of time in order for that to happen from that type of setup. I've been around the car scene for years, never once heard of it happening.
    Nov 2005
    Princeton, NJ
    Quote Originally Posted by nighthawk06si View Post
    People don't realize that while your car is in movement, there is a lot of air circulation which would change the under hood temperature. I have also yet to see any proof that the Intake Temperatures were lower in one setup than the other...mainly because its insignificant and they probably aren't. Just because you're getting air from one source at one temperature, doesn't mean by time it travels through your intake system that it will be that same termpature...it would only be different if there was a drastic change it ambient temperature (like going from 50 degrees outside to 80 degrees outside). Changing the source of your air location isn't going to make a big different either way.
    Also, the only thing CAI do is make the path of air flow longer, making intake velocity slower....even for a turbocharged vehicle, especially because most CAI setups are 3" in diameter making the volume larger and path longer since its extending to the fender area. Thats something to consider.
