What is the best catless uppipe for a 2002 WRX? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
This is a discussion on What is the best catless uppipe for a 2002 WRX? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I absolutely love it... I will do that on every turbo setup I ever have. The performance boost is fantastic ...
    Registered User MrSweet's Avatar
    Apr 2011
    Marylandistan
    The performance boost is fantastic and the sound is insane (a good tuner is a must, of course). I personally think its worth the money if you want to get the most out of your setup.
    2007 SWP WRX - Blouch EVO III 16g'd - 320 WHP/330 TQ, tuned by Jorge @ P&L Motorsports
    2002 WRX Wagon - The DD, the workhorse, the snowboard-trip-whip, the turbo grocery getter
    Always remember... life is short.
    Registered User 2002SubieWRX's Avatar
    Apr 2010
    North Seattle area
    So GrimmSpeed's YouTube install video says a professional tune is highly recommended after installing a their uppipe but I have read all over this forum it's not needed. Anybody with experience out there please respond. Thanks!
    - 2013 BRZ Limited, WRB, manual
    - 2002 WRX WRB Sport Wagon (Stage 1) SOLD
    - 1968 Mercury Cougar w/ custom 331ci stroker & 5-spd
    ~Best 1/4 mi ET: 13.00 Video here--> http://s55.photobucket.com/albums/g1...t=MVI_0378.mp4
    ~Best 1/4 mi Trap Speed: 109mph
    Quote Originally Posted by 2002SubieWRX
    No need. Plug the EGT sensor with a resistor and call it a day.
    Sent from my Droid using Tapatalk
    Resident Tuner @ WTF Tuning
  6. #19
    Apr 2010
    North Seattle area
    That's what I thought. I bought the resistor yesterday at Radio Shack but didn't get to it. The car is still up on stands in my garage after working on it from 6:30 PM to 11:15PM last night I watched the install video GrimmSpeed put out on YouTube and they make it look so quick and easy. They did say they didn't show the heat shield removal process because they didn't have enought time in the video. I guess I know why now.
    Another question: Is it a bad idea to keep the heat shields off or should they be installed again? The top shield on the passenger side manifold was a pain to get out and I'm not too excited about putting it back in.
  7. #20
    Apr 2011
    Marylandistan
    Quote Originally Posted by 2002SubieWRX View Post
    The only heat shields that are still on my car are the manifold ones. I did however spray and wrap my uppipe before installation.
  8. #21
    Apr 2010
    North Seattle area
    Quote Originally Posted by MrSweet View Post
    How long have you been running without the other ones?
  9. #22
    Nov 2009
    Yes it is important to keep your heat shields. They do more then you think. Do the job right and put them back on.
  10. #23
    Apr 2010
    North Seattle area
    Quote Originally Posted by oguitar View Post
    Thanks for the encouragement. I sometimes get a little impatient and just want to get the thing back together. I finished up after midnight last night and did install all the factory heat shields back on. To make it easier to get the lower passenger side manifold shield on with the O2 sensor in place I hack sawed a section out and that made it much easier.
    Took it out for a test drive and it for sure spools lower in the RPM range and also much quicker I think the mod bug has just bit me again! Before it was on my 1968 Mercury Cougar that now sits in the garage waiting for my attention
  11. #24
    Apr 2010
    North Seattle area
    Well, a slight rattle somewhere in the post-turbo exhaust has developed since putting the up-pipe in and re-installing the exhaust heat shield components. I'll have it up on the ramps again tonight to see what the problem is. If I had the money, it would have been nice to buy a Cobb stage 2 kit and install all new turbo back exhaust instead of having to put the stock stuff back on. Probably wouldn't have rattling with all new piping. Some day...
    EDIT: Well I found what was making the noise. I forgot to put a bolt in the bracket that secures the exhaust to the transmission. It would vibrate only at certain RPMs. I don't know where the bolt went so I used one of the two left over bolts after the uppipe install. The GrimmSpeed uppipe comes with 5 new studs and nuts for mounting to the turbo and two new bolts and nuts for mounting to the crossover pipe.
  12. #25
    Aug 2009
    If you get the ceramic coating, do you not need to wrap the pipe or do anything special for insulation? Is that only true if you put the heat shields back on?
  13. #26
    Apr 2010
    North Seattle area
    Quote Originally Posted by Recon_Six View Post
    You could always use heat wrap too, but it most likely wouldn't make any difference. The function of the ceramic coating is to retain the heat within the pipe. The heat shields won't fit on an aftermarket flange unless they have tabs for the shields to attach to. Again, the ceramic coating serves the same function of the heat shields.
  14. #27
    Oct 2011
    Oregon/Cali/Texas
    uh oh, someone didnt do a FOD check!!
