Results 1 to 14 of 14
This is a discussion on electric vs. mechanical gauges? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Im getting a Prosport Boost and EGT gauge.... whats the deal/difference between an electric boost gauge and a mechanical gauge? ...
    Registered User wrex5's Avatar
    Feb 2011
    rockland, new york
    Im getting a Prosport Boost and EGT gauge.... whats the deal/difference between an electric boost gauge and a mechanical gauge? thanks....
    Hawk-Eye Alliance #1796
    "Now looks like a good time"
    Apr 2007
    8000' up in Colorado
    Cars have gone to electronics in the last 20-30 years for a reason. However, mechanical gives you something that'll never go because of a fuse or electrical problem. I often struggle with this given my built 77 Ford. That's purely mechanical including the fuel pump and everything else and it's much simpler. But that's old school. Today electrical/electronic rules.
    Scott
    Jan 2005
    Eh, whaaaaa?
    Electronic gauge will have a module somewhere in the engine bay for hooking into your vaccuum lines, then you'll just have to run wires from there to the gauge. Mechanical you will have to run the vaccuum line (from a T you will install) to the gauge, as well as wiring it up for lighting and what not.
    Either way you have about the same amount of work. The electronic gauge often gives better results, though, but they are far more expensive.
    Cody
    Registered User sjcurtis's Avatar
    Sep 2010
    Selma, Alabama
    I like running wires alot better than trying to get the vaccuum line thourgh the firewall.
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by sjcurtis View Post
    There are grommets, it's really not that difficult.
    Cody
    Feb 2011
    rockland, new york
    thanks for the info guys... looks like im goin electric
    Moderator Donkey's Avatar
    Da boonies
    2002 FORESTER S
    1998 FORESTER S
    Registered User spnkdrm's Avatar
    Southern CT
    Thats why when I did my boost gauge, I did an electrical. With my luck, i would have pinched the line...
    My friend had an evo8 for a while and we did a mechanical one - PITA compared to the electrical in my opinion.
    New EnglandF4
    Hawk-Eye Alliance #010
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    I have a bit of a different theory on this. Both my Boost and my oil pressure gauges are mechanical. I consider them the most important, and I intentionally chose mechanical gauges for those two.
    Simply put, because there is less to go "wrong". They are more simple.
    Everything else however, is electrical.
    Just my thoughts on the matter.
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
    Jul 2010
    Cincinnati
    My opinion is that I'd use a mechanical boost, but any that involve fluids will be electrical. I don't want oil running through the cabin.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    zax
    zax is offline
    Moderating the World! zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by jd92677 View Post
    +1 to this. It seems that electronic gauges have a small amount of a lag present from digital sampling. For something like oil temperature/oil pressure, that's OK... But a parameter that continuously varies from high to low (like boost) should be monitored by a mechanical gauge.
    Facebook me here
    Mar 2006
    SLC area
    Agreed... which is why I use copper tubing on my OP gauge. That nylon stuff will wear out eventually.
    5 years... haven't had a leak yet with my OP.
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/showthread.php?t=165158
    Feb 2011
    rockland, new york
    damn.I just ordered an electric boost gauge the other night. guess i shouldve went mechanical with that. so the mechanical gets a more accurate read is what ure saying?.
    Jul 2010
    Cincinnati
    Quote Originally Posted by wrex5 View Post
    I don't know if it is more accurate if the electrical gauge is working properly, but there is less to go wrong with a mechanical gauge.
    Stink eye mob #727
