Results 1 to 15 of 16
This is a discussion on My Bugeye Build within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey Guys, As some of you may know i have started my second build with the bugeye. The first build ...
    Registered User shorty38's Avatar
    Aug 2009
    Minnesota
    My Bugeye Build
    Hey Guys,
    As some of you may know i have started my second build with the bugeye. The first build consisted of a 68HTA and a hybrid motor. It made 354 on the dyno with e85. That was somewhat disappointing for how much money i had invested. But it was still a pretty fun DD. About 3 weeks after having it tuned i shattered my rear differential. I then decided it was time for a 6 speed to avoid any more problems. After putting about 2000 miles on it for some odd reason the rings didn't seal right or something along those lines and i decided it was time to redo it again. I pulled the motor and ended up finding three bent exhaust valves also. I wanted some more power so i decided to redo it all.
    The mod list:
    Engine Internals
    -2.5 STI block
    -CP standard sized pistons
    -Eagle Rods
    -ACL main and rod bearings
    -New Oem Oil pump
    -ARP case half bolts
    Heads
    -Ported and Polished heads by me
    -BC 272 cams
    -Supertech intake and exhaust valves
    -Cometic head gasket
    -BC valve springs and retainers
    Drivetrain
    -06 Sti transmission and rear diff
    -DCCDpro Universal controller
    -Quarter Masters twin disk clutch
    Turbo
    -ATP GT35R externally gated
    -Tial 44mm WG
    -TurboXS FMIC
    -FIC 900cc's for now (I am currently in the market for something bigger. If you have anything PM me)
    -Perrin Fuel rail kit
    Exhaust
    -Megan Header/uppipe
    -Custom 3" TBE
    -Magnaflow Muffler
    Many of these parts i am waiting to show up yet. My goal is for over 500hp. I think i have what i need to make it but if you have any advice or suggestions as to what i might still need let me know. My dad and I have done all the work to this thing except the machining. And before anyone might say that i am spoiled, I have payed for everything on this car and have had a full time job throughout highschool.
    Heres a couple pictures of the car.
    Here is how lazy i was during the last build. Yes the engine bay is half black half silver.
    I had to fix that during this build. Here are the results.
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    Where is the door handles? How would one get inside your car??
    Lead Wrench @ WTF Tuning, LLC
    Feb 2011
    Shaved door handles with poppers huh pretty sweet and like the color to. But what are you doing with the front diff are u keeping it stock to or putting in one from the 6 speed line up. Just wondering cause of the gear ratio and all.
    Aug 2009
    Minnesota
    It has the sti front and rear dif. And yes i have little actuators that open the doors. I wish i never would of done it for my dd. But i was 16 and stupid.
    Registered User Shansen2's Avatar
    Mar 2010
    Spearfish, SD
    Looks good!!
    Aug 2009
    Minnesota
    Thanks
    Dec 2004
    Your Mommas
    Im just messin with you on the door poppers... I would paint the grille extensions to match the car, Id also get some kind of lip kit to go with that wilder color of paint/shaved door handles you chose.. Just my .02
    Aug 2009
    Minnesota
    The grill is actually a jdm one that was carbon fiber but faded too much so its just flat black for now. i have a stock grill with the ends painted the same but i like this better. And yea i want to get one but i dont like most of the ones out there. I want the oem bugeye lip. I think it looks pretty good without being ricey.
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    Looks good
    Aug 2009
    Minnesota
    Thanks.
    Aug 2009
    Minnesota
    Just a little update. I recently recieved my killer b utlimate pan and pickup, an atp GT35r, turbo xs fmic and the quarter master twin disk. Hopefully i can get my machinist to get my block and heads done tomorrow.
    Dec 2003
    Dallas, TX / Sterling, VA
    You're gonna have a hell of a time hitting 500 on that setup. The ATP turbo is limited compared to rotated 35Rs and the TXS FMIC is going to hold you back as well. You may also want to pick different cams (BCs are known for bad idle and no power) and springs and retainers (lots of engine builders hate BC's valvetrains).
    Aug 2009
    Minnesota
    The stock location gt35r turbo is capable of 600 +. as for the bc valvtrain, i will max it out and when i get money i might replace it. I have a Perrin Stealth core but i bought it with no piping so i may just retrofit the turbo xs piping for the stealth core. I have talked to my tuner and he thinks that it should be capable of 500 with 1300 injectors
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    Good for you for paying for it all yourself. I've also worked all through high school and college and pay for everything on my car and respect that. Good luck with your build
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
    Dec 2003
    The piping is the restriction on the TurboXS kit.
