info
Results 1 to 10 of 10
This is a discussion on info within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Sup to all sub fans i was searching around and found a site www.speedyracer.com and found a T3/T4 hybrid turbo ...
    Nov 2010
    info
    2" Outlet Diameter
    Journal Bearing - Wet Float Type
    T3 Flange
    2.5" V-Band Outlet
    Oil Lube/Cool
    400 HP Capable
    Compressor Wheel
    0.50 A/R Cold Side, T04B Housing
    Ind: 56.06 mm
    Exd: 65.20 mm
    Trim: 73.9
    Turbine Wheel
    0.58 5-Bolt Standard Hot Side
    Ind: 70.00 mm
    Exd: 54.14 mm
    anyone knows if these turbos r any good holla back
    Jan 2005
    Eh, whaaaaa?
    *bangs head on desk*
    I take it you're looking at that turbo because it's cheap as all mighty hell?
    Just letting you know, there would be a LOT more work to get that to work than you're probably willing to do, and by the looks of it, a lot more money than you'd be willing to spend.
    I suggest you read the stickies at the top of this subforum before you attempt to do any modifications to your vehicle. I can only assume you're a young person who is rather new to the car game. That or you've just made the jump from old ass civics to Subarus.
    Cody
    Nov 2010
    info
    well boss u got muh number i had a 98 Ek civic type R and i added some parts
    T3/T4 Hybrid Turbocharger
    Intercooler 27x6.5x3 (Direct Bolt-on)
    2.25” Aluminized Mandrel Bent Piping (Total of 4)
    High Pressure Silicon Hose (Total of 6)
    Clamps (Total of 21)
    Cast Iron Turbo Manifold
    2.5” Stainless Steel Down pipe
    Stainless Steel Connect Pipe
    Stainless Steel Dump Pipe
    Blow Off Valve
    38mm Waste gate 7 psi
    Valve Set for Waste Gate
    Gasket Kit for Waste Gate
    Steel Braided Oil Feed Line
    Oil Return Line
    Oil Pan Fitting
    Vacuum Tee’s
    Vacuum Lines
    Gaskets and Bolts
    skunk2 inlet
    aem fuel rail
    the car was fast but i drove a 4wd sub and i had to get one
    so i am starting with a gc8 old but i just love those shape might later get a newer version but fuh now i need info on this machine
  5. #4
    Jan 2005
    Eh, whaaaaa?
    I see, so you're looking at turbocharging an N/A GC eh? That's going to be a bit of a challenge in and of itself. There are kits out there for supercharging or turbocharging that generation, but be aware that those motors were never built for boost. They won't last long.
    They're great autox cars though, you can make them into autox monsters relatively easy, but power wise, you can't really expect much without swapping in other motors.
    Welcome to the Subaru scene. Nice job on the Civic, but be aware that the Subaru scene is quite a bit different than the Honda one. Feel free to look around and if you have questions just let us know.
    Cody
  6. #5
    Nov 2010
    info
    no its a wrx it is standard with a td05 but need more power
  7. #6
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by bajan630 View Post
    Oh ho! So you're outside of the US then? Or am I just not getting what's going on in here? What are the details of your car from start to finish?
    Cody
  8. #7
    Nov 2010
    info
    ok its a 98 impreza gc8 wrx everything is standard only thing i did was to upgrade the breaks to six pot front and 4 to the back and added tein suspension that was it... now i am interesting on getting more power
  9. #8
    Jan 2005
    Eh, whaaaaa?
    Very cool. Where are you located?
    This forum is really pretty much specific to the USDM WRX and STI, so there won't be as much information available for your car, but there are other very good forums for your generation and maybe even for your area.
    Cody
  10. #9
    Nov 2010
    info
    i'm from Barbados if u dont know where that is its in the caribbean lol
  11. #10
    Jan 2005
    Eh, whaaaaa?
    lol I actually do know where that is, that's cool. I'm not sure if there are any specific regional forums for you, but I know there are other forums out there for your generation with all kinds of information. A quick google search should yield up some good results
    Sorry I can't really be of more assistance with your car, they're actually a bit different from ours, so the information isn't as readily available to us.
    Cody
