Port the turbo
Results 1 to 10 of 10
This is a discussion on Port the turbo within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey guys, Im going to port my oem turbo on my 07 wrx, Do I need new turbo gaskets? OEM ...
    Registered User weboyd87's Avatar
    May 2010
    PA
    Port the turbo
    Hey guys,
    Im going to port my oem turbo on my 07 wrx, Do I need new turbo gaskets? OEM bolts? Can anyone who has done this or who knows how to do this give me a list of the parts I should get? And maybe a good place to order from? I know I need, new oil, coolent and Id assume new gaskets. But Im not sure. Ill take all the info and help I can get, Thanks!
    The Hawk-Eye Alliance 102289
    Registered User armindk's Avatar
    Dec 2009
    louisville, ky
    Why do you need to port it? If it's power you are after there are a lot of different and more reliable ways to get there.
    May 2010
    PA
    Im going to port it to prevent boost creep. Im going to a stage 2 map on my 07 wrx and this is a common problem. Everyone says porting the turbo will correct this.
    New gaskets and hardware (studs, nuts, bolts). Even if you don't end up using the new hardware, it's worth it to have just in case.
    As for porting, unless you're confident with your experience and abilities, I'd consider sending it off to have someone professional do it.
    Resident Tuner @ WTF Tuning
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by weboyd87 View Post
    No offense but if you have to ask if you need new gaskets or not maybe you should leave this to a professional. Porting a turbo is not really for a novice. A lso a ported turbo will require a custom map. No OTS map will support it.
    2002 FORESTER S
    1998 FORESTER S
    May 2010
    PA
    No I'm not doing it by myself. I have a mechanic friend who has done it to vws hes gonna take a look and if its too differnt then im gonna take it to a local speed shop
    And I figured id need new gaskets and bolts but I wanted to double check and also see if anyone reccomends a cheap site to order from. If not then I'm gonna just order from the dealer.
    May 2010
    PA
    So cobbs stage 2 map won't work for a ported turbo? What do you suggest then to fix this problem of mine ?
    Thanks for your help. I'm newer to this but I want to learn and you gotta start somewhere
    So cobbs stage 2 map won't work for a ported turbo? What do you suggest then to fix this problem of mine?
    Some cars creep, some don't.
    You don't currently have a problem; cross that bridge if you get there...
    Jan 2009
    North Platte NE
    I have a 06 all catless and no boost creep problem. Its mostly the lack of backpressure that will cause creep. Are u using a hiflow cat. Maybe you sould get to stg2 befor you try to fix a problem you may not have.
    Boost > NA itWRXjustfine's Avatar
    Aug 2009
    Fort Riley
    +1.
    2004 Impreza Outback Sport - Sold
    2004 WRB WRX - Sold
    2006 SGM WRX - 400AWHP - Mods
    My 2006 Build
