WARNING FOR BUYING CATTED DOWNPIPES!!! - Page 5
Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 97
This is a discussion on WARNING FOR BUYING CATTED DOWNPIPES!!! within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Sinister BPMs do have a cat and a resonator in the midpipe. So I believe you. As ...
  1. #61
    Registered User spnkdrm's Avatar
    Southern CT
    As for your inspection... if you were tested at 1118, that means it was probably an idle test. So you're lucky. You don't live in a state that does advanced smog testing.
    I made sure to drive around for a while to warm it up to be safe, because on a cold morning it smells like a gas station. After it was done, I talked to the tech and asked specifically what they did out of curiosity. In CT, because it is an AWD car made after 1996 there was no dyno test - just a visual and ODBII - dont rememebr anything about a sniffer.
    New EnglandF4
    Hawk-Eye Alliance #010
  3. #62
    Jul 2010
    Cincinnati
    Quote Originally Posted by spnkdrm View Post
    They don't do sniffers on OBDII cars much anymore. They only check for codes and check that all monitors have tested and passed. I did wonder how a flashed ECU dealt with monitors, I guess I know now, good deal!
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
  4. #63
    Quote Originally Posted by jd92677
    You can disable codes and force readiness with Romraider.
    Resident Tuner @ WTF Tuning
  6. #64
    Registered User chronicawd's Avatar
    Mar 2011
    long island NY
    if you are really that concerned perrin makes a two section down pipe with two high flow cats but if you really want power go get a catless down pipe for half the money n keep ur old down pipe the swap once a year take s a hour tops just man up n do it
  7. #65
    Registered User Black_N_Blue2002's Avatar
    Jul 2011
    Seattle
    Hey guys just a heads up from my expirience with the unhappy emmissions booths in Washington is that the tests are more strict based on regional population. So say in Seattle the test is very strict and in Po-Dunk eastern washington emmissions aren't required. I don't know if that applies country wide, but it is something to keep in mind for you area when getting ready for your car's next prostate exam.
  8. #66
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    That's true here in colorado too.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  9. #67
    Mar 2011
    long island NY
    if it is really strict there i always a shop that will pass u for a few more bucks
  10. #68
    Nov 2006
    Denver Metro Area
    our state doesn't have shops do it. There are state ran testing stations.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  11. #69
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    ^^ Not necessarily... Any turbo subaru has high EGTs... but NA blocks do not. For some reason the 2006/07 2.5 Imprezas do have high NOx... but only in cold weather. There was something up at the testing station regarding the 2.5 Impreza from 06/07
    What does the a/f and timing mapping look like? cold air and not enough low temp fuel compensation+some advance on the timing and nox output will climb pretty fast.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
  12. #70
    Registered User crisco's Avatar
    Jun 2011
    Skyline Drive
    my car came catless, but i figured why pollute the environment for a 1% gain? and the smell was bad, and iit was too loud for my tastes.
    so i added a vibrant racing cat and i like it alot better.
    its a win-win! 99% of the performance of catless, with a 90+% reduction in emissions.
    --- 1999 Impreza WRX STI JDM Version 5 Sedan ----
  13. #71
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    Threw my stock dp on today for my emissions test, and passed!
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
  14. #72
    Mar 2011
    long island NY
    so easy to do as well
  15. #73
    Jun 2011
    Skyline Drive
    Quote Originally Posted by jd92677 View Post
    I disagree that it would be more stress on the grid, most people would charge their cars during off peak times, when the plants are producing much more power than is demanded and therefore using power that is otherwise discharged by the power company. The electricity is being generated off-peak whether we are using it or not and that is one of the largest inefficiencies of the power grid so we would actually be creating a more efficient infrastructure by using this power.
    qfp..........
  16. #74
    Oct 2002
    this thread is amusing. back in the hey day i had a 2002 wrx running a CAI, and 3" TBE.
    had the uppipe factory cat, and 1 highflow cat on the downpipe. passed in cali.
    now trying to determine what to do for '11 sti sedan. just started researching today
    lambosv21
  17. #75
    Apr 2012
    Just to clarify, AWD Subarus in California do not receive a dynamometer test (all dynos are 2wd.) In which case, NOx cannot be measured. Keep in mind there is also a visual inspection for your catalytic converters and any replacement has to be CARB certified to pass!
