Results 1 to 3 of 3
This is a discussion on DIY: Intake Silencer Elbow within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So as most people with the 02-07's do with their intake silencer, this mod enables you to delete your intake ...
    Boost > NA itWRXjustfine's Avatar
    Aug 2009
    Fort Riley
    So as most people with the 02-07's do with their intake silencer, this mod enables you to delete your intake silencer, hear your turbo and BPV better, not leave you with a gaping hole in your fender, and most importantly save $$. Aftermarket units cost upwards to $50 and you can make one out of your silencer for as much as a black tube of RTV costs.
    Tools needed:
    Rotary Cutting Device or Saw.
    Snips
    RTV
    1. Take a grinder, saw-zall, or some sort of cutting device to separate the two chambers of the silencer at the thinnest part.
    2. Make sure that you smooth out and make sure that the surface on the elbow is level.
    3. Cut out a square off of the bottom of the silencer to use that as your plug. Use a pair of snips to keep honing down that plug.
    4. Once you have the size right, apply a liberal line of RTV around the bottom of your elbow.
    5. Run your hand around the mating surface and make sure that it is air tight, the sealant is evenly applied, and clean up the bead.
    Now even if you don't connect it to anything, you don't have a hole in your fender and it blocks water or if you have it hooked up to your stock system, it will really open up your turbo sound. Enjoy!
    2004 Impreza Outback Sport - Sold
    2004 WRB WRX - Sold
    2006 SGM WRX - 400AWHP - Mods
    My 2006 Build
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    I did pretty much the same thing except I drilled a 3/8 in. hole in the bottom plate to allow water to drain out like the snorkus had. Works and sounds great.
    Aug 2009
    Fort Riley
    Awesome, yeah I mainly made mine to block water from the fender well. I am running a SRI.
    2004 WRB WRX - Sold
    My 2006 Build
