ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Engine Modifications
Engine Modifications Flat-fours and turbochargers are what set the WRX apart from the rest. Talk about them and the latest aftermarket parts here.
Advertise On ClubWRX
View Poll Results: 02 bugeye with... kicks ass
vf-34 5 41.67%
vf-39 4 33.33%
vf-43 3 25.00%
Multiple Choice Poll. Voters: 12. You may not vote on this poll
Reply
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 02-01-2010, 03:32 PM   #1 (permalink)
wrxlaunch's Avatar
VF-43 bugeye?
Hey gals n guys, I just picked up a vf43 and a STi top mount for a really good price, both with low miles. I plan on using modded wrx injectors txs turbo back, upgraded fuel pump and an open source tune.
I have a 02 wrx with 119xxx miles. Is this a good idea? and no I don't plan on beating the tranny, just want to enjoy the hell out of it.
__________________
Elapsed Time = 13.986 @96.11mph, RT=0.08, 60'=1.938,
02 Wrx: Turbo XS Up-Pipe,Spt intake,mbc set to 1bar and Turbo XS RFL axle back. 114xxx miles
wrxlaunch is offline   Reply With Quote
Old 02-01-2010, 03:34 PM   #2 (permalink)
jeremy96gase's Avatar
I'd do a compression test before installing your new blower, make sure your engine is healthy enough to handle the power
jeremy96gase is offline   Reply With Quote
Old 02-01-2010, 03:40 PM   #3 (permalink)
N00b Moderator mit das motion lotion
EJ257's Avatar
Quote:
^ This ^
If it passes, then have at it
__________________
2005 WRX STi (Mods | Dyno)
CNYSubarus
EJ257 is offline   Reply With Quote
Old 02-01-2010, 03:41 PM   #4 (permalink)
wrxlaunch's Avatar
Thanks for the advice... I will have it done in the a.m. Its currently getting some suspension work.
What do u think of the vf-43 tho?
__________________
Old 02-01-2010, 03:45 PM   #5 (permalink)
I'm not sure what the point of your poll is. Didn't you already buy the VF43?
The three turbos you put in your poll are very similar.
The VF43 is almost identical to the VF39, except, IIRC, it's less likely to have the wastegate crack.
The VF34 is technically a better turbo due to its bearing design.
All three produce about the same power.
Edit: Comparing the VF39 and VF43
VF39 and VF43 directly compared! - Subaru Forester Owners Forum
Old 02-01-2010, 04:00 PM   #6 (permalink)
wrxlaunch's Avatar
U answered my question... The best choice u said wld be the vf34. I can always sell the vf43. I'm in no hurry to install the parts. Thanks for ur input,
__________________
Old 02-01-2010, 04:07 PM   #7 (permalink)
EJ257's Avatar
Quote:
On a budget, you can't go wrong with the VF39/43 because they're so readily available for cheap.
The VF34 is a better turbo on the 2.0L engine.
However, over all three, I'd recommend this:
Blouch Turbo Inc. - Our performance turbo upgrades and rebuilds
It's cheaper than a new VF34, comes PnP'd from Blouch, and is considered one of the best (if not the best) DD turbo for the 2.0L engine.
__________________
CNYSubarus
Old 02-01-2010, 04:20 PM   #8 (permalink)
The EVO III 16G is better than all three VF's, but it's hard to beat the price of a good used VF.
Old 02-01-2010, 04:22 PM   #9 (permalink)
EJ257's Avatar
Except a used EvoIII
While it won't touch the price of the 39/43, it'll be similar to the 34.
__________________
CNYSubarus
Old 02-01-2010, 04:25 PM   #10 (permalink)
Got me there.
Old 02-01-2010, 04:34 PM   #11 (permalink)
Of the 3 mentioned in the VF series I'd probably go with the VF34. The ball bearing design will spool 500 RPM sooner than the others. Peak flow is about the same, as is ultimate power production capability.
That Blouch unit looks sweet! Obviously a better turbo than any of the VFs mentioned, but if cost is a factor a used VF39 is hard to beat and they are everywhere.
TKO Performance is offline   Reply With Quote
Old 02-07-2010, 07:25 AM   #12 (permalink)
Post number 962 on www.clubwrx.net
Greatings, Thank you! I would now go on this blog every day!
Thanks
nolivefeel com/]SuperSonic
Doggy is offline   Reply With Quote
Old 02-07-2010, 07:44 AM   #13 (permalink)
wrxlaunch's Avatar
Parts list so far:
Turbo xs stealth back -used $280 w/ 4"dp
STi TMIC -$150
VF-43 -with 40k miles $300
STi pinks- $200
Walboro fuel pump -$80
Aem wideband -$180
Labor for turbo install -$275+$50 for stealth back+ TMIC
$230 for injectors and $350 for open source tune to be done be DPS.
Fuel pump and wideband I'll install myself and then dyno time.
Do u think an oil pressure gauge is worth it and do I need to get after market bov? Boost should be around ~21psi max.
__________________
Old 02-07-2010, 08:56 AM   #14 (permalink)
Aftermarket BOVs are junk. All they do is make noise. There is no benefit, until you get into a really far out there setup that requires one, but you'll also be running an EWG then too. Otherwise stay stock. Aftermarket BOVs have a bad rep, and turbo damage and other problems have been linked to them.
The labor prices look decent, but I have to ask why you feel comfortable installing as fuel pump but not swapping out the turbo? It's not that hard and there are plenty of people here who can help you if you get in a bind.
Old 02-07-2010, 11:01 AM   #15 (permalink)
wrxlaunch's Avatar
Fuel pump will only take a 1/2hr at most. I'd do the turbo swap but I don't have all the tools I need or stands so I can do the exhaust at the same time. How long will it take to install the turbo and how difficult is it
__________________
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
wheel fitment mhawkin3 Suspension & Wheels 5 08-10-2009 07:39 PM
Information about all VF Turbos silverbullet>>> Engine Modifications 2 09-21-2007 08:03 AM
vf 43 setup vvnartvv12 Transmission & AWD 6 06-19-2007 05:28 AM
P0335 Crank Position A efmd3 General Maintenance, Troubleshooting & Accidents. 11 04-02-2007 01:51 PM
VF 24 or VF 30 veritas Engine Modifications 2 09-09-2002 01:24 AM
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
You Rated this Thread:
