Attn '02-'05 WRX Owners: The Importance of the Uppipe Mod - Page 9
Closed Thread
Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 121 to 135 of 159
This is a discussion on Attn '02-'05 WRX Owners: The Importance of the Uppipe Mod within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by SKI.WRX FWIW I recently passed Colorado emissions testing with no pre-turbo catalytic converter and stock turbo back. ...
  1. #121
    Registered User nateleeg's Avatar
    Mar 2013
    Las Vegas, NV
    Quote Originally Posted by SKI.WRX View Post
    FWIW
    I recently passed Colorado emissions testing with no pre-turbo catalytic converter and stock turbo back. they did no visual inspection only a sniffer test and OBDII. I could have had 10 times the levels I had and still pass. you could probably still pass with only 1 of the factory cats in place. I have the resistor fix in place.
    Good to know. Living in Vegas, I've never had someone do a visual inspection, but I also never had a modified car. I'm thinking I might just like to get an up-pipe with a bung for the sensor. I'm confused though, if you gut the cat converter and put the sensor back on, shouldn't it throw a CEL? Granted I'll be stoked if it doesn't, but it seems odd
    Quick reply to this message Reply
  3. #122
    Quote Originally Posted by nateleeg
    The EGT sensor is only there to monitor the catalytic converter temp, it's not useful for EGT readings like when you install a gauge (which you typically tap in the exhaust manifold in the #4 runner. Since there is no cat, you don't leave the EGT sensor to possibly get sucked into the turbine. You want an uppipe without a bung, ideally, but if you get an uppipe with one, you plug it with a bolt and toss the EGT sensor in the trash, and plug the connection with a resistor.
    Resident Tuner @ WTF Tuning
  4. #123
    Mar 2013
    Las Vegas, NV
    Makes sense, thanks. Now I'm debating between a solid pipe, or the flex pipe. I can't help but the think the flex is a bad idea
  6. #124
    A good uppipe with a flex section is ideal, IMO. TurboXS and Grimmspeed both make good ones.
  7. #125
    Oct 2005
    Late Devonian
    A really good UP doesn't need a flex if it fits perfectly.
    I've had zero issues with my crucial for many years of use, and have never heard of any from any other user.
    YMMV.
  8. #126
    Registered User Hogdweeb's Avatar
    Sep 2013
    North Egremont, Massachusetts, United States
    Replacing the uppipe with one that has no cat...will that cause emission issues at inspection? If I have to replace my engine I'm gonna rip out the factory uppipe before i drop in my replacement for the sake of ease.... unless emisisons will arise
  9. #127
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Hogdweeb View Post
    Yes.
    Sent from my Nexus 5 using Tapatalk
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  10. #128
    Sep 2013
    Yes.
    So how could I possibly get by this? not like a turbo back where i plop my factory on and keep it from spooling....
  11. #129
            MainFrame's Avatar
    Austin, TX
    Resistor fix.. read the thread, I'm sure this has been discussed.
  12. #130
    Sep 2013
    the resistor fix doesnt help with the fact that I wont get by emissions... which leads me to keeping the factory on, and i dont feel like dancing with the devil and sucking part of the cat into my turbo, so can i get around it?
  13. #131
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    How will the up pipe make you fail emissions? It's pre-turbo exhaust.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
  14. #132
    Sep 2013
    Quote Originally Posted by michaelwfox View Post
    Thats what I thought, but a couple posts previous zax said it would cause emissions problems...
  15. #133
    Nov 2011
    North GA
    Only because it will throw a CEL. That is where the resistor fix comes in.
    Sent from my Galaxy S4 (typo, schmypo)
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
  16. #134
    Palmyra, NJ
    No CEL, no problem. Visual inspection will still see the cats in the stock DP. Zach just didn't exactly fully explain himself.
  17. #135
    Sep 2013
    so as long as i get one with a cat i'll be good? if thats the case, will i still run the chance of sucking parts of it into my turbo?
Closed Thread
