kronosperformance has it for $180. PM them and see if they will price match.
GrimmSpeed 02-10+ WRX/STi/LGT Uppipe w/ Black Ceramic Coating [grm003002] - $180.00 : Kronos Performance, Leading since 6th Century BC
This is a discussion on Attn '02-'05 WRX Owners: The Importance of the Uppipe Mod within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Thank you, so ill just keep the stock one when i need to get the car smogged. i read earlier ...
Thank you, so ill just keep the stock one when i need to get the car smogged. i read earlier that this is a good price for the grimmspeed ceramic coated up pipe 175.99 plus shipping i believe
GrimmSpeed Ceramic Coated Uppipe Subaru Models (inc. 2002-2011 WRX / STI) at RallySportDirect.com
is there a better place to buy one or is rallysportdirect the best option?
i iz a noob!
www.garageworks.co/
looks like a PITA job. the youtube videos always make it look so easy and are always missing a few key steps (i.e. removing the heat shield). if they videotaped it the FIRST time they did the job, it would scare people off from buying the pipe and installing it. not to mention all the swearing in the video.
meh, i may get around to it at some point if i get bored and have a day to kill messing with my care when it's not so freaking hot out.
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
2005 Toyota Solara SE 2.4L
i iz a noob!
www.garageworks.co/
‪GrimmSpeed Up Pipe Install‬‏ - YouTube
This should take you to the YouTube video. If it doesn't, just type in "GrimmSpeed Up Pipe Install".
- 2002 WRX WRB Sport Wagon (Stage 1) SOLD
- 2005 Tundra SR5 Ext - Wife's DD
- 1990 Geo Metro hatch - The new DD cuz it gets 50+ mpg without even trying
- 1968 Mercury Cougar w/ custom 331ci stroker & 5-spd
~Best 1/4 mi ET: 13.00 Video here--> http://s55.photobucket.com/albums/g1...t=MVI_0378.mp4
~Best 1/4 mi Trap Speed: 109mph
i iz a noob!
www.garageworks.co/
i iz a noob!
www.garageworks.co/
hay all so im most likely going to get this up pipe, do you guys think i would need any more hardware, like gaskets etc? thanks
i iz a noob!
www.garageworks.co/
i iz a noob!
www.garageworks.co/
Definitely gasket, probably at least one stud, plus one resistor. Buy PB Blaster and band-aids too.
cool, any specific size stud and the resistor is for the egt? how does that work, just plug it in and good to go? and yes ill make sure to have plenty of band-aids and rubbing alcohol. most likely going to have 2 of my buddies also, and have a few beers to entice them to help
i iz a noob!
www.garageworks.co/
The GrimmSpeed kit comes with all the studs and nuts you need. Yes, you should purchase new gaskets for every location you open up. RallySportDirect.com also sells GrimmSpeed gaskets. Check out this thread for more good information: What is the best catless uppipe for a 2002 WRX?.
i iz a noob!
www.garageworks.co/
i iz a noob!
www.garageworks.co/
