Heat wrap / coating will help retain heat which helps prevent heat soak and maintain gas velocity. For what they charge you for it, it's worth buying the coated version.Originally Posted by subiwagon03
Gaskets for each connection you "break" (this will depend on your install method); usually turbo/uppipe, uppipe/manifold, and turbo/downpipe.Originally Posted by subiwagon03
On this Grimmspeed uppipe, nothing. They offer external wastegate uppipes which can use the plate if you buy the pipe and don't buy the gate itself.Originally Posted by subiwagon03
See aboveOriginally Posted by subiwagon03
LinkBack URL
About LinkBacks
