Attn '02-'05 WRX Owners: The Importance of the Uppipe Mod - Page 10
Closed Thread
Page 10 of 11 FirstFirst 1234567891011 LastLast
Results 136 to 150 of 159
This is a discussion on Attn '02-'05 WRX Owners: The Importance of the Uppipe Mod within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; The idea behind replacing the Uppipe is to get one without a cat. Plain and simple. That's all. Then you ...
  1. #136
    Palmyra, NJ
    The idea behind replacing the Uppipe is to get one without a cat. Plain and simple. That's all. Then you do the resistor fix for the sensor so you don't throw a CEL. Problem solved. No longer will you put your turbo at risk.
    Quick reply to this message Reply
  3. #137
    Registered User Hogdweeb's Avatar
    Sep 2013
    North Egremont, Massachusetts, United States
    Thanks mikie for the info.
  4. #138
    Dec 2013
    Michigan
    I just bought a 2004 wrx wagon, bone stock. first thing performance wise that i wanna do is the uppipe, im not that good with engines but im willing to learn. is it hard to replace? and if im going to do replace the whole exhaust system at some point in the near future should i just do it all at once?
  6. #139
    Registered User SilverSemoWrx's Avatar
    Oct 2013
    Jackson Missouri
    Quote Originally Posted by tjkuip0 View Post
    Replacing the up pipe and replacing the exhaust are on two different sides of the turbo. You do disconnect the downpipe during up pipe installation though. Grimmspeed has a video on how the up pipe is replaced. Check it out on youtube
    ~2004 Subaru Wrx - Stage 2
    ~2013 Honda Civic
    -I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming.
    -Nobody remembers the guy who finished second but the guy who finished second.
    -Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.
  7. #140
    Dec 2013
    Michigan
    Quote Originally Posted by SilverSemoWrx View Post
    would it b a wise choice to do headers at the same time as the uppipe?
  8. #141
    Nov 2013
    Reason being is you have to disconnect the exhaust manifold anyways , so you might as well do headers at the same time if you are planning on doing it. Same with a downpipe IMO.
    Loosen turbo , remove exhaust manifold and swing the stock up pipe out of there. Sometimes you have to jack up the motor slightly to get the stock up to come out.
    Sent from my Nexus 5 using Tapatalk
  9. #142
    Nov 2013
    Also - I'd suggest finding a shop to do the up pipe swap if you are not comfortable doing it yourself. You will thank yourself later. Especially If you run into any stud issues.
  10. #143
    Dec 2013
    Michigan
    Quote Originally Posted by mmmsti View Post
    ya i am going to have a shop do the uppipe but should i do headers at the same time? since the shop will b lifting the whole motor out anyways?
  11. #144
    Nov 2013
    Why is the whole motor coming out ? The headers r a personal choice. R u worried about smog at all ?
  12. #145
    Dec 2013
    Michigan
    maybe i was wrongly informed.. i was told the whole engine had to b lifted up to replace the uppipe..
  13. #146
    Nov 2013
    No. You sometimes need to slightly jack up the motor but it doesn't involve removing the motor. The heatsheild is the issue. It gets caught up at times which is why you MAY need to slightly jack up the motor.
  14. #147
    Registered User mikewondo's Avatar
    Jan 2013
    Mountain Center, California
    I wouldnt waste money on headers,,,,sounds like a sooped up Honda....I have EL Tomei Headers on...going back to stock or Grimmspeeds set up..
  15. #148
    Nov 2013
    Quote Originally Posted by mikewondo View Post
    You don't have to use EL headers. There are aftermarket UEL headers that are well worth it for a stage 2+ setup.
  16. #149
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    EL headers are not just sound. Yes, they do take the token "subaru rumble" away, which I admit, I love too, but they can add a significant amount of performance if matched with the right upgrades and tuned for correctly.
  17. #150
    Nov 2013
    EL headers are not just sound. Yes, they do take the tolken "subaru rumble" away, which I admit, I love too, but they can add a significant amount of performance if matched with the right upgrades and tuned for correctly.
    Well, so can aftermarket UEL headers. The main difference between the two is the resulting power bands each has to offer.
Closed Thread
