First Modifications - what to do and not to do - Page 14
Page 14 of 16 FirstFirst ... 45678910111213141516 LastLast
Results 196 to 210 of 236
This is a discussion on First Modifications - what to do and not to do within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by CoolGuyRx2 I'm planning on creating a custom system that will be quiet, eliminate drone, and gives fantastic ...
  1. #196
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by CoolGuyRx2 View Post
    I'm planning on creating a custom system that will be quiet, eliminate drone, and gives fantastic flow.
    3" piping from the cat, one Racing Beat 3" rotary resonator, and one 3" Rotaflo rear can with a 4" dump...considering splicing in a 3" remote cutout after the resi and before the diff.
    All of the remote cutouts I've seen leak profusely.. and the motors tend to burn out repeatedly.
  3. #197
    Registered User Bizzdan's Avatar
    Jun 2014
    Salem Oregon
    Is there anything different on the 14wrx that anyone knows? Great thread btw
  4. #198
    Registered User Peanuts's Avatar
    Feb 2014
    Sydney, Australia
    This will work with Stock, Stage 1 or 2 with down pipe. Resonator is about $115 and the rear is around $300..piping, say $80-100. Around the $500 mark with proven flow, muffing, and performance. Similar price as just the muff deletes!
    Subi's are already quieter than rotaries on any given day, I have a good feeling....stay tuned!
    I'm currently using a Xforce Varex dual kit. Both mufflers have a butterfly valve allowing a straight through design & with the valve closed the gases are diverted into the muffler chamber before exiting through a hidden port.
    Here's a video demonstration on my WRX - http://youtu.be/X6RkpFnkxr4
    Varex has been used on many cars at Powertune Australia. Cars with well over 500hp.
  6. #199
    Nov 2013
    Just wondering if its necessary to get the accessport installed before you put in a a cold air intake? I have the perrin cold air intake. my car is the 2005 wrx 2.0l
  7. #200
    Jul 2012
    Rocky Top
    Yes, do them both at the same time or the accessport first. Unless cobb has come out with a new map for that intake, your perrin intake will not work with the maps you download from Cobb's website (OTS maps), you will need a custom tune or risk potential problems with the OTS maps. Read the "map notes" to determine what intake systems they support.
  8. #201
    Feb 2015
    Houston, TX
    Looking for some advice. I'm a first time subbie owner with a 2010 sti. Current mods include:
    Cobb intake, downpipe, and AP at stage 2
    Kartboy short shift and front/rear shift bushings
    Cusco front tower bar
    In mail is a kartboy pitch stop and cusco rear tower bar, with quick release bolts
    Next pieces I'm going to be putting in are:
    Eibach lowering springs (1") with 25mm front and 22mm rear sways
    Kartboy front and rear endlinks
    Beatrush engine and tranny mounts
    Process west tmic
    And looking at possibly a mishimoto rad fan setup.
    Also, is a carbon fiber drive shaft really worth it?
    This is a progressive build and I've had the car for about 7 months now. I loved it. And now love it more. I have been doing all the work myself, even if some of it is new to me. I plan on doing as much as i can by myself unless necessary due to extreme difficulty or time required (i work usually 6 days a week.) I planned it to be a dd with occasional autox, but I'm not afraid of a "non cushy ride".
    So. Comments on current mods and planned mods. Advice on anything i may have over looked. Right now, i plan on working on suspension stuff but thinking i would like a bit more power down the road, as it wont take me long to get use to cobb ap stage 2.
    Any advice will be greatly appreciated. Glad i joined, reminds me a bit of the old forum i was in. I use to have an s12 (aka 84-88 200sx)
  9. #202
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by smartell84 View Post
    Process west tmic
    Skip the lowering springs and go with RCE black springs. Steering rack bushings, shifter pivot bushings (I thought this made a much bigger difference with the slop - side to side - and it's very cheap - Turn in Concepts), rear diff inserts, SS brake lines/fluid wash, better tires (I'm partial to michelin pilot super sports), and custom alignment (I maxed the front and rear camber).
  10. #203
    Supporting Member livid_wrx's Avatar
    Mar 2014
    South East Michigan
    Welcome to ClubDub! Go with what 11blackSTi said, I've only ever heard good things about RCE
  11. #204
    Feb 2015
    Houston, TX
    Thanks for the info, I'll look into them. Some of what you listed i was looking into but was unsure of the real difference it made. Annnnnd i already have the tires.
  12. #205
    Feb 2015
    Houston, TX
    So, did some reading and decided on the RCE yellows. Also, some RCE sways afterwards. Thanks for the info.
  13. #206
    Mar 2014
    South East Michigan
    Welcome, come back and tell us how they work out.
  14. #207
    something else forever Germz to Japz's Avatar
    Jul 2014
    Herndon Virginia
    front and back or just back?
    Speak Your Mind & Let Me Know
  15. #208
    Feb 2015
    Houston, TX
    Getting both front and rear. 0.6" drop in height for both front and rear. 330lb and 335lb are the front/rear spring rates.
    I was hoping to drop it a little lower but I'll deal for those spring rates.
  16. #209
    Jul 2014
    Herndon Virginia
    solid dude solid!
  17. #210
    May 2015
    Looking for some advice I'm new here just recently purchased 2015 wrx, I'm looking into giving it some more power & torque , I've recently got a custom exhaust done.
    Some stuff I want to get is coilovers I was debating between tein mono sports and fortune auto wasn't sure which ones are better. And upgrade my tires/wheels to some 18x9.5 wasn't sure what size tires
    Also was thinking about getting AP and probably getting an etune from brentuning, I know he has a etune for stock wrx to give a little push.
    Any advice guys?
