Results 1 to 9 of 9
This is a discussion on what is this? between manifold and intake (post MAF) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; OK, this is probably a very noob question, but before I get flamed, could someone answer this question ? there ...
    zax
    zax is offline
    Moderating the World! zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    there is a small "device" that connects the manifold directly to the intake (post MAF), and I can't seem to determine its function. I know it's not the BPV and the only thing I can think is that it's related to the boost pressure gauge. Someone let me know!!
    Facebook me here
    Moderator Donkey's Avatar
    Da boonies
    Its a one way valve for the EVAP system...................
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Nov 2008
    So that's the purge valve for the EVAP sysetm? Good to know. Thanks Donkey!
    Facebook me here
    Boost > NA itWRXjustfine's Avatar
    Aug 2009
    Fort Riley
    If this valve is functioning properly, would you throw a P0442?
    2004 Impreza Outback Sport - Sold
    2004 WRB WRX - Sold
    2006 SGM WRX - 400AWHP - Mods
    My 2006 Build
    Da boonies
    Well the actual purge valve is the electronic solenoid bolted to the manifold right under that. It should be plumbed inline right before the one way valve.
    2002 FORESTER S
    1998 FORESTER S
    Da boonies
    Quote Originally Posted by itWRXjustfine View Post
    Yes as there are a couple of other valves in the system. There are actually two solenoid controlled purge valves. One at the charcoal canister and one at the manifold.
    \/ Link to service manuals
    Factory Service Manuals
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Nov 2008
    If my limited knowledge of the EVAP control system is correct, shouldn't the valve be attached to a charcoal storage container ... but why does it run back into the intake?
    Facebook me here
    Da boonies
    Because the manifold vacuum is what is used to transfer the gasoline vapors from the gas tank to the combustion chamber. This method has only been used since the 1970's...... Not to mention I provided everyone with a link the factory manual diagrams. Maybe take a look at those first.
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Nov 2008
    Ah, yes you did. Didn't even see the link to the service manual. Taking a look now...
    Facebook me here
