Stage 2 set up
Results 1 to 15 of 16
This is a discussion on Stage 2 set up within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; ive been looking into purchasing the cobb stage 2 package for my 06 wrx i already have a injen cold ...
    May 2009
    Stage 2 set up
    ive been looking into purchasing the cobb stage 2 package for my 06 wrx i already have a injen cold air intake the cobb stage 2 kit is acess port v2 the downpipe and catted exaust any sugestions on other things to do or problems i may run into or how this combo will work out for me?
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    You won't be able to run the CAI w/stage 2 unless you are protuned..... Put the stocker back in
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    May 2009
    its not gonna hurt having the CAI there though just wont preform to its full potential till i get a protune correct?
    Quote Originally Posted by b00sted06
    Injen CAIs have skewed the AFR pretty badly in the past. Unless you have a wideband O2 sensor and monitor the AFRs, I would not install it until you're getting a tune.
    Resident Tuner @ WTF Tuning
    May 2007
    orlando flawduh
    injen intakes are known to have problems.
    the map notes for cobb stage 2 says to use ONLY your stock intake or a cobb intake.
    however there are some brands you can use that will not mess with your air/fuel ratio that you can technically use with your cobb map.
    injen is NOT one of them.
    desiree
    Registered User Spencer3636's Avatar
    Apr 2009
    No-Town
    I have an Injen But hey I even have a Manual Boost Control
    The trick is, I just came off the laptop and the wide band.
    My A/F was all kinds of jacked up before the tune.
    Either way, keep in mind that the Cobb maps they supply are simply base maps so a tune is a good idea anyways.
    Carpe Diem!
    My 03 Bugeye is cooler than your mom
    Bugeye Mafia #222
    May 2009
    yeah i got a buddy with a 2000 sti with an 04 engine in it and he told me today that he needs to get his protuned also so me and him are gonna end up going together soon hopefully so i can just get some maps that run the stage 2 with my CAI otherwise ill probly just put it all in but not intstall my stage 2 map for a bit untill it gets tuned
    Dec 2003
    Dallas, TX / Sterling, VA
    Some intakes are fine to run on a generic tune. However the Injen is one of the worst possible choices to have gone with. If you're gonna keep it on, you're gonna need a custom tune for it.
    Registered User jpjester's Avatar
    Apr 2007
    Doylestown PA
    Quote Originally Posted by b00sted06 View Post
    I am kind of torn, do you put on the downpipe and exhaust + have that intake on and drive around town with the STOCK TUNE or ...
    Just use your Accessport and put on the Cobb Stage 2 map until your protune.
    I am leaning towards "just use your Accessport and put on the Cobb Stage 2 map until your protune. ?
    Previous Subarus:
    2004 Subaru WRX, 18G Deadbolt Zilla setup w/ Supporting Mods
    2009 Subaru WRX Hatchback Stock!
    Apr 2007
    Doylestown PA
    Quote Originally Posted by brfatal View Post
    I actually recommend the SPT Short Ram Intake or the Perrin
    Previous Subarus:
    May 2009
    well im thinking that ill just leave the stock tune on and leave the intake DP and exaust and once i go to get it tuned ill get it tuned with the stage 2 map loaded but im open for suggestions i mean i CAN put the stock intake on but i dont really wanna do that id have to get it from home and everything but running it with the stock map witht the DP exaust and CAI would be fine correct? just not near as much power till the car gets tuned
    May 2009
    mostly do this because ive heard u can run into alot of problems with running a CAI with the cobb stage 2 kit so id rather just run a stock tune till it gets tuned there is a place pretty close that id be going to within this next month
    May 2007
    orlando flawduh
    i would NOT install these mods without having your accessport
    if youre going to install them- you need to stay OUT of boost until you get some form of EM. (do you really want to risk damaging your vehicle?)
    it really just makes more sense til you have everything in your possession that way you can install then flash right away with the AP (assuming thats what youre still getting)
    desiree
    May 2009
    i do have the AP im just saying i dont wanna risk damage on my vehical i have the parts im just waiting to install what i can when i know its a good idea so you are saying run a stock tune if the DP and exaust are in with the CAI but dont boost alot and just go easy untill i get a tune on it
    May 2007
    orlando flawduh
    im confused.
    you cant run a stock tune with those parts. THAT will damage your vehicle.
    you need to run a stage 2 map from the AP.
    if you have your AP, why would you run a stock map?
    thats what i dont understand.
    unless youre getting the terminology mixed up.
    the maps on the AP are "off the shelf maps" you CAN safely use those without any further tuning
    you do not need to buy the AP, flash to their maps and THEN get a pro-tune unless you really want to. i think thats a waste of money though. if youre getting a custom tune anyway- you might as well sell the AP and go straight to your local tuner.
    desiree
