2009 WRX Dyno Pull
Results 1 to 11 of 11
This is a discussion on 2009 WRX Dyno Pull within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Stock 2009 WRX....
    Registered User AtomicFrawg's Avatar
    Dec 2008
    Its NannerPuss!
    2009 WRX Dyno Pull
    Stock 2009 WRX.
    R.I.P 2004 Supercharged Miata
    Hellllllooooo 2009 WRX
    Aug 2008
    Great #'s!
    Is Open Source Tunning available to the 09 yet?
    I want that VF52 turbo for my 08!!!
    Registered User turbotwist's Avatar
    Dec 2008
    ri
    nice numbers. I love those new 09s
    Jan 2008
    Nebraska
    Im interested to see how well this new turbo can be tuned. Like how well it can hold a higher boost till redline. Probably akin to a similarly sized IHI I suppose.
    Thanks for the post OP!
    Dec 2008
    Its NannerPuss!
    your welcome
    video anyone
    YouTube - AWD Dyno Day 2.1.09 - '09 WRX
    RomRaider supports 09's
    COBB stage 1 im hearing is around 256hp and stage 2 around 292hp.
    After this pull I was very happy I bought this over an Evo X. Not to mention the 10k+ savings.
    Feb 2004
    Evansville, IN
    Quote Originally Posted by xsnapshot View Post
    The VF52 is essentially a VF39/43 in LGT/+08 WRX fitment.
    Below is a link to my VF52'd LGT at 19psi peak, holding 15psi or so at redline, weather has been sh1tty here so my tuning has been put on hold until the roads clear which should be another day or 2 at most:
    testes1010's 2005 LGT thread
    I generally tune 04-07 STi's to ~21psi peak holding ~17psi at redline on our good 93 octane we have here. So my LGT should have another 2psi in it or so on stock injectors pushing it right up over the 320whp mark. With +650cc injectors and a larger fuel pump the turbo could hold 22-24psi peak(super aggressive) making torque skyrocket up to the 360wtq neighborhood.
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
    Nov 2008
    Quote Originally Posted by AtomicFrawg View Post
    your welcome
    video anyone
    i just flashed my 09 wrx to stage 1 and go for spin. you will notice the car pulled harder then stock. especially from 4k all the way to redline
    Registered User For Realsss's Avatar
    Mar 2008
    Redding, CA
    Quote Originally Posted by testes1010 View Post
    I heard the stock BOV and IC on the '08/'09's has issues after 15psi (might be 20?). I think it might have been the Perrin '08 that had the BOV pop off during their toying.
    Jun 2008
    Georgia
    I had no problems with my '08 when I was running the stock TMIC and BPV while pushing 16-16.5 psi.
    2011 WRX Sedan
    315 WHP / 354 WTQ
    Dec 2008
    Its NannerPuss!
    On the other forums I hear they are pushing 20 psi on stock gear. I plan on upgrading the BOV anyway to the perrin recirculated BOV at stage 2. The only thing I can see the would be bad on the IC is heat soak.
    Feb 2004
    Evansville, IN
    Quote Originally Posted by For Realsss View Post
    ImsureitwasaploytosellmorePERRINBovs
    1988 Celica Alltrac
