ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Engine Modifications
Engine Modifications Flat-fours and turbochargers are what set the WRX apart from the rest. Talk about them and the latest aftermarket parts here. Sponsored by JSC Speed
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 12-01-2008, 08:31 PM   #16 (permalink)
itzconvict2's Avatar
whats the difference between a TBE and COBB?
i was thinkin of sending my turbo in to blouch and have them upgrade it and then put sti injectors in would that work?
itzconvict2 is offline   Reply With Quote
Old 12-01-2008, 08:37 PM   #17 (permalink)
VisciousJay's Avatar
Send a message via Yahoo to VisciousJay
If tbe=tanabe..I haven't heard much about it but I'm new to the subaru community;But, I've heard about Cobb making quality parts for Subaru's prior to owning my Wrx.
__________________
2006 Obsidian Black Subaru WRX TR
HKS Hi-Power Cat-Back
Smoked Tails
VisciousJay is offline   Reply With Quote
Old 12-01-2008, 08:40 PM   #18 (permalink)
yea same here i have two friends that put uppipes and downpipes and then did the COBB tuning i wanna do that but i want more hp
Old 12-01-2008, 09:49 PM   #19 (permalink)
CrazyMonk's Avatar
Send a message via AIM to CrazyMonk Send a message via MSN to CrazyMonk
why is everyone soo freakin snappy on here? chill out peoples... keep personal anger at home.
dude i would suggest startin out with going stage 2 or somethin simple at first, before dumpin a s*** load of money into your car. then move on up to getting the full potential out of your money. which u gotta tell me how that works out for yah....cause i have an 06 too
__________________
------->Live to Drive<--------
CrazyMonk is offline   Reply With Quote
Old 12-01-2008, 10:58 PM   #20 (permalink)
aight i will haha
so wat is stage two for 06's?
I know its COBB but is it an up pipe and a down pipe also?
Old 12-02-2008, 12:02 AM   #21 (permalink)
CrazyMonk's Avatar
i don't believe it has to necessarily be cobb, but up & down pipe, catback exhaust, with a tune or engine management system. i have been readin around the threads and it looks like 06's can put down some pretty good numbers with just going stage 2.
__________________
Old 12-02-2008, 01:24 AM   #22 (permalink)
aight i was just wonderin, thats not to bad and wat do the numbers look like?
Old 12-02-2008, 05:22 AM   #23 (permalink)
pzr2874's Avatar
No up-pipe is needed... Unless you want to do it.
__________________
Paul
2007 WRX
pzr2874 is offline   Reply With Quote
Old 12-02-2008, 05:47 AM   #24 (permalink)
idipskoalmint's Avatar
Quote:
With an OTS map (e.g., Cobb AP), an aftermarket UP is unnecessary - you will not see gains from purchasing one.
However, if you're going to be getting a custom tune, an aftermarket UP will net you some gains. If you decide to go this route, look into the Grimmspeed UP (you can get it ceramic coated for $200, and you'll just need to hit up your Subaru dealership for OEM UP/EM and UP/turbo gaskets).
If it were me, I'd do the following:
TBE of your choice - $600 (buy used)
Grimmspeed UP (ceramic coated) - $200
Custom open-source StageII tune - $400
OEM gaskets (DP/turbo, DP/CBE, UP/EM, UP/turbo) - $35
Total: ~$1200
This would give you a good bump in power, and you could sell your OEM catless UP for $50-75 to recoup some of the money you've spent.
__________________
CarDomain
WRXModders
2005 DomTune'd WRX STi
idipskoalmint is offline   Reply With Quote
Old 12-02-2008, 08:39 AM   #25 (permalink)
pzr2874's Avatar
Total: ~$1200
Add another 200.00 for S&H.... highway robbery I tell ya.
__________________
Paul
2007 WRX
Old 12-02-2008, 09:37 AM   #26 (permalink)
Supporting Member
Pavia's Avatar
I would go for stage 2 for now. Good advice above ^^^, but basically what you are looking to do is increase the flow of your exhaust, while using a new software tune to get your car's computer to raise the boost of the stock turbo (and a whole lot of other stuff to optimize your cars parameters).
On a 06 WRX you would be near stock 06 STI levels and maybe better in terms of torque. Most people here refer to horsepower levels as they are at the wheels of the car, rather than the base horsepower of the engine at the crank. For example, when I went to stage 2, I dyno'd at the wheels 224hp and 285 foot lbs of torque. With powertrain losses, maybe we're talking 260ish hp and 310ish torque at the engine crank. So stage 2 can be comparable to a stock STI in terms of power.
Stage 2 components are generally a TBE (Turbo Back Exhaust) with or without a catalytic converter in the DP (Downpipe). The DP is the first part of your TBE that connects to the turbo. 06-07 WRX's do not have a cat in the UP (Uppipe), so it's not necessary for just stage 2 (but it's good for more power if you upgrade the engine further). A retune of your cars ECU is next. You need to change the software of your car to take advantage of your new exhaust.
The best is to have a professional put it on a dyno and do a custom tune. The cheapest is to use premade tunes you can download from the internet and transfer to your car via a laptop and cable. A more expensive way is to get a Cobb Accessport. This is a small handheld device that has preloaded tunes on it that try to match various "stages" or hardware packages that most people go with. You hook it up to your cars OBDII port and load it yourself. It also has a lot of other features.
You go stage 2, then work on upgrading your suspension, and I think you'll be very happy for a while.
P.S. I vote no for the BOV as well...
__________________
06 GTO M6 Quicksilver 455 Bobcat
07 WRX TR M5 Garnet Red Pearl
- Stage: I've given up on "stages". I spent way too much cash and my car's running fine (dyno'd 315whp/334wtq). I'm stage "hiding my receipts from the wife..."
Pavia is offline   Reply With Quote
Old 12-02-2008, 12:17 PM   #27 (permalink)
aight thanks bro that helped alot
Old 12-02-2008, 03:45 PM   #28 (permalink)
just to clear up, TBE=Turboback or Tanabe......
__________________
Smoked Tails
Old 12-02-2008, 07:00 PM   #29 (permalink)
i got ya, if i do turbo back exhaust can i still get my car smoged or will i still have to keep my cats?
Old 12-02-2008, 07:32 PM   #30 (permalink)
ajd111's Avatar
You will pay a little more, but you can buy a downpipe with a high flow cat and be fine.
__________________
Quote:
Originally Posted by BrianH View Post
Careful, I still think she's packin wang.
ajd111 is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
New England F4 Roll Call D0WNxSH1FT New England States 114 11-17-2008 12:59 PM
OAKOS Automotive - Cobb, EnduraTech, RacingBrake, Carbotech, Kartboy, and More!!! OakosAutomotive Vendor's Forum 13 08-08-2008 11:36 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
