Page 11 of 20 FirstFirst ... 234567891011121314151617181920 LastLast
Results 151 to 165 of 297
This is a discussion on 914er's project "SPOILED BRAT" progress thread within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Awesome!!...
  1. #151
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Awesome!!
  2. #152
    Registered User FyrHazard's Avatar
    Mar 2010
    Iowa
    I just found this thread and am promptly subscribing! That thing is nice. Good work. I've always liked the Brats.
    "Good design is a lot like clear thinking made visual." - Edward Tufte
    Bugeye Mafia #314
  3. #153
    Jun 2010
    Hi there
    I found this thread surfing the net and am sorry to say that a wrx motor can fit in a 78 brat (brumby here) as I have done it about 6 years ago.
    It is a crap load of work though as the rails have to be widened quite a lot!
    My brumby has a 98 wrx motor and drivetrain 5 stud conversion, wrx brakes (4 pot) 450hp turbo and lots of other bits along the way
    If you want any info let me know
    Total cost of my ute was about 15k aud but I did everything myslef.
    Cheers Troy
    Attached Thumbnails Attached Thumbnails DCP_0014.jpg   MVC-025F.JPG   MVC-028F.JPG   MVC-031F.JPG   MVC-034F.JPG
  4. #154
    Oct 2005
    Late Devonian
    Quote Originally Posted by 78sti View Post
    Hi there
    Cheers Troy
  5. #155
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    Hi there
    Cheers Troy
    Very very cool, but it looks like you accidentally put the steering column on the wrong side!
  6. #156
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    Holy crap..... that is amazing!
    Did you have to replace the whole front subframe with a later-year Brat model?? I've heard that that is about the only way it can be done??
    Or did you just notch the framerails?? Is there anything left of the framerails? How far did you have to cut into them??
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
  7. #157
    Jun 2010
    The rails were moved/ pushed out from in front of the crossmember by removing a wedge shape peice from the inner guard, cutting through the bottom radiator support and cutting through bottom half of headlight frame (around the chasie rail). The the rail was pushed accross and everything was welded back up and strengthened and made to look like nothing had changed.
    The crossmember had massive modifications as well as the engine hit the crossmember on the edges and a huge cutout was required for the exhaust up pipe.
    The gearbox only just fit (about 5mm) and the motor and box was actually lowered in the car a little to fit. I probably should have put a larger tunnel in.
    After that everything else was pretty much straight forward!
    The build took me 1 year to do the modifications/ conversion and about another year to do the body work paint and interior.
  8. #158
    Jun 2010
    A bit more on motor options.
    -ea81 turbo out of later brats but not that exiciting!
    will drop straight in but you will need the gearbox as well, the best box for this is a late 80's 5 speed this will bolt to this motor and the front driveshafts will fit straigh on (i think) all you need to do is make a suitable gearbox support crossmember, mount and shorten the linkages and get a longer tailshaft made. You may also need to mod the steering coupling where it comes out of the rack.
    -Ea82 turbo not worth the trouble.
    -EJ22 sohc this would be the best option as it will fit with minimal modification, I am sure a performance shop could do something special with this also, you may be able to use these heads on a wrx motor with custom cams? or I have also seen these supercharged.
    Use the gearbox that comes with this motor the front driveshafts do line up and can be made to fit by using second hand bits from other subarus. Again tailshaft, crossmember and linkages will be required.
    -EJ20 turbo dohc as you are aware this requires massive amounts of work but I did not want to settle for anything less.
    I would suggest what ever you do CHANGE THE GEARBOX these old boxes will brake with and sort of power in front of them. It was common in the 80's to upgrade these to later boxes even with the origional motor.
  9. #159
    Mar 2006
    SLC area
    Man.... that's a pretty impressive build. I dunno man.... I haven't even had the time to put it back together after the paint. Its to the point now where I just want to get it registered so I can drive it loll.
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/showthread.php?t=165158
  10. #160
    Mar 2006
    SLC area
    So...... I found these pair of Brats for sale on KSL. I'd love to have them both... but I have no place to put them..... and man.,..... these things are ROUGH.... WAY worse than mine was when I bought it.... and they haven't run in YEARS...... just about like every other Brat you see.
    http://www.ksl.com/index.php?nid=218...=subaru%20brat
    Anyway.... I was able to convince the owner to sell me just the brush guard for $50. I have NEVER seen one of these for sale... EVER.... ANYWHERE. OEM Brat parts are tough enough to find.... but original aftermarket parts from the 1970s??? .... are damn near impossible.
    I bet I could sell this thing on eBay for over $300.... yay me!
    Anyway.. I HATE the look of the front bumper, and I've vowed not to use it.... but this should help me get through inspections, and look pretty damn cool too. I'm going to add a cross bar to serve as a "bumper"... which should just be a matter of welding a straight pipe across the middle of it that is the same width as the car. Then, I'm going to have it powdercoated chrome to match my new OEM rear bumper
    So here it is.... in all of it's infinite uglyness..... but it's not rusted through, and should look fantastic after a good sandblasting and powdercoat.
    Got my OEM BRAT decals installed yesterday evening as well!!!!! Custom made by B&R sign in Oregon..... in SILVER Still haven't removed the application tape yet.. more pics to follow in the next day or two though!!
  11. #161
    Mar 2006
    SLC area
    Man...... I got SOOOOOOOO much done today...
    1) Peeled off the contact paper for the new decals
    2) Popped about 1000 little bubbles and smoothed it out.
    3) Got the headlights working, high and low beams (that has NEVER worked since I've owned it)
    4) All marker lights on all 4 corners working (also never worked)
    5) license plate lights working for the first time.
    6) installed a 40 amp circuit breaker to replace bad fusable link
    7) cleaned and replaced fusebox (badly corroded) and installed all new fuses.
    Still to do:
    1) overheating problem (knew about that when I bought it)
    2) Horn
    3) powdercoat new front brush guard chrome
    4) tires
    6) paint wheels silver to match stripes
    7) seats
    8) seatbelts
    9) pass inspection.... get it registered
    Today's pics:
  12. #162
    Mt. Laurel, NJ
    Badass!!!
    Throw some Hellas or PIAAs on the crash bar!
  13. #163
  14. #164
    Mar 2006
    SLC area
    Badass!!!
    Thanks man!!
    I dunno..... I LOVE the look of the front end of this car so much.... It's my favorite aspect of this car, and the reason I insisted on a 1st gen Brat..... I hate to clutter it up.
    The brush guard (or crash bar) is really just an "attempt" to make it legal and get it through inspections, while still maintaining the integrity and good looks of the front end.
    Because I REFUSE to put the front bumper back on (although I still have it, just in case the inspection folks give me a hard time)... it is so f-ing ugly, and such a huge design flaw on these cars.
  15. #165
    Mt. Laurel, NJ
    Quote Originally Posted by ninefourteener View Post
    Thanks man!!
    I agree with you on the looks. It looks great and will look great with the brush guard on it IMO. Hopefully it does work out for you. IMO, I don't think lights on the bar would clutter it up at all...but then again, its your Brat
