Glad you're back up and running![]()
This is a discussion on Hybrid Build - Done!!! within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; The abridged version: rod knock on my '05 WRX w/ 2.0L (stage 2 Cobb OTS map) = 2.5L hybrid build. ...
The abridged version: rod knock on my '05 WRX w/ 2.0L (stage 2 Cobb OTS map) = 2.5L hybrid build. Machines Gone Wild in Kendal did the build. 319.50hp, 293.90 torque at 16 PSI (very conservative tune).
Specs:
2.5L Hybrid setup
Kelford Cams
Cosworth Head Gaskets
CP Pistons
Valve Springs
Head Studs
Perrin TMIC
DW 650cc injectors
Walbro 255
Blouch 18g 8cm
Cobb Intake w/airbox
New stock parts: clutch disc, timing belt, oil pump, v-belt, accessory belt, water pump
Gauges: AEM UEGO (wideband A/F), oil pressure, boost
Edit: Newest Tune and info Below....
Got a retune and the only changes are as follows:
Perrin Inlet
Grimmspeed EBCS
NGK Iridium Spark Plugs (one step colder)
STi Oil Pan w/KillerB Oil Pickup
Kartboy Pitchstop
More Boost (was 16PSI, now 19PSI)
Old dyno results: 318.85whp, 288.37trq (16PSI, Temp: 87.90F, 41% humidity)
Current/New: 332.47whp, 338.78trq (19PSI, Temp: 97.37F, 28% humidity)
Both were on the same DynoJet and done by the same tuner, who also built my block (Gregg of Machines Gone Wild). The car has almost 85K miles and the block has 24K.![]()
Break in is done and now at about 800 miles.
I am getting tuned tomorrow morning, I will be sure to post the results.
Keep us updated.
Update:
I was unable to get tuned today. My tuner did not get back from his trip until this afternoon...so I am hoping to reschedule for this Sat...but I won't know until tomorrow. Took off today from work too.
Update:
Tuning is now scheduled for this Saturday at 10:30AM!
Results to follow.
good luck!![]()
desiree
06 impreza wrx tr: cobb stage II - protuned by STi_Mikey!
hawk-eye alliance #11:11 // wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
cant wait!
05 WRX Wagon *sold*
99 Civic SI *ITR 5 Lug-16x8 Dunlop CP-R's*
06+ WRX soon??
sounds like a great set up. be prepared to spend that $3,000![]()
"Never Launched"![]()
Dougie - Founder, 250,000 mile club
-5,000 posts
319.50HP, 293.90Torque
Very conservative tune at 16PSI, my tuner said she had plenty left...but still got the stock tranny so we decided to stop there.
Drives like a bat out of hell...power every where, just NASTY!
Dyno Chart to follow.
glad your done goodluck with the car. quick question though being that the blouch 18g has the 8cm turbine housing is it laggy at all?
03 WRB WRX STAGE II
STi COMING SOON
BUGEYE MAFIA #199
LET ME QUOTE THE LATE COLONEL SANDERS " I'M TO DRUNK TO TASTE THIS CHICKEN . . ."
Not really, if there is any I can't tell...it feels way way more powerful than stage 2 2.0L at every part of the power band and in every gear and pulls hard all the way to redline. The best part is its still fairly low boost and a conservative tune, so there is definitely more untapped power to make in the future....But, the tranny upgrade will have to come 1st.
yea you are at low psi the 18gs can run up to 28 psi so there is deff alot more power there. but yea a tranny would be a good idea first
03 WRB WRX STAGE II
STi COMING SOON
BUGEYE MAFIA #199
See Post #1 for my dyno chart.
Almost 300hp until 7000rpm....thats what Cams dones folks, very little drop off at the higher RPMs.
nice numbers, goodluck with it!!
05 WRX Wagon *sold*
06+ WRX soon??
