engine tune with uppipe install???? please help
Results 1 to 15 of 17
This is a discussion on engine tune with uppipe install???? please help within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; tomarrow im getting an uppipe istalled in my wrx. is there anything i need to do to help the car ...
    Registered User IkeTurner's Avatar
    Jul 2007
    mass
    tomarrow im getting an uppipe istalled in my wrx. is there anything i need to do to help the car adjust to the new engine part?
    Every time chrome rims are put on a subaru a kitten is killed. do you want to be responsible for the death of a kitten?....do you?
    Jan 2005
    Canada B.C.
    No, Maybe an ECU re set is all I would do...
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    get a downpipe and flash to stage 2
    2005 WRB WRX "was" STAGE 2
    Feb 2008
    ^^^^Why are you putting that in here? He's asking about the Uppipe wrt to tuning. Installing a DP is another issue.
    Nope. Shouldn't really need to tune with the uppipe.
    Jul 2007
    mass
    great thanks guys
    Sep 2007
    Sacramento, CA
    Quote Originally Posted by White GDA View Post
    Because it WILL need a tune, like most every other mod you put on your car needs. When the up pipe it put on he will now be spooling about 500rpms sooner. Pressures will change with the cat no longer being between the exhaust manifold, and turbo. Also the check engine light will appear. If you get or have a downpipe, its better for your engine to flash to stage 2, you will clear the CELs, gain power, and the engine will be tuned and run smooth.
    If he posts back with an EGT CEL all this could simply be pointed out to him again. If he were to install a downpipe now is the logical time to do so to save on labour and effort, but it's not necessary.
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by jeffmm06 View Post
    2.2 ohms resistor mod.
    I wouldnt think you'd see much gains from tuning after just a UP on a other wise stock car.
    With that being said if you plan on doing a TBE just do it all at once and be done with it.
    Feb 2008
    Nuh uh.
    For starters, I run a catless UP on a stock DP, with no complaints, no CELs (did the 2.2k ohm resistor mod). There are also folks who've done the UP mods w/o the resistor mod, and seemed to have gotten away with it (by putting the EGT back in the uppipe).
    My car was protuned before UP install....and there was little change after in boost pressures (as expected).
    The only gain is reduction in spool time, and probably a little peak hp somewhere (don't quote me on the last figure).
    Yep. Your DP would prob. have to come off anyway to do the install. I did for my install. So if you've you wanna put in an aftermarket DP, that's a good a time as any to do so.
    Jul 2007
    mass
    what is this 2.2 ohm resister mod
    Search for resistor mod, there's many threads.
    ClubWRX.net Vendor
    May 2007
    St. Paul, MN
    make sure you have new gaskets and everything ya need for install than you should be good to go. Reset ECU is not a bad idea either as stated above. good luck!
    GrimmSpeed
    Registered User WRXmeade's Avatar
    Mar 2008
    VA
    Just did a Cobb Uppipe a month ago (lots of scraped knuckles, but fun)
    FYI its a 2.2 kOhm Resistor (thats 2,200 Ohms, its listed a few different ways below.) I did this 'mod' and would definitely recommend it as its a $0.05 deal.
    EM shouldn't need to be changed (per Matt at Cobb) because the onboard em will eventually learn to deal with the faster spool.
    Having said this, big bump for the DOWNPIPE... this is the best time for the install since you have to take off the stock DP anyway. Plus a DP will alter performance way more than the UP anyway.
    Mar 2013
    Greenville, SC
    I've been looking at putting a catless uppipe on and same as you my car is already protuned. I'm currently using a helix down pipe with high flow cat and am thinking that the new uppipe will require a retune after its installed. Do you think I could get away with out retuning?
    Quote Originally Posted by bmoose
    If your car has a catted uppipe, and you replace it with a catless unit, you could put yourself into untuned load sites. It's best to have it looked at and touched up. An uppipe shouldn't be too difficult to adjust for.
    Resident Tuner @ WTF Tuning
