Would you like some cams with that?
Results 1 to 8 of 8
This is a discussion on Would you like some cams with that? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Cams, are they worth it? does the engine have to be removed? Judging by the extreme pain in the ass ...
    Registered User ericmalvarez's Avatar
    Miami, Fl.
    Cams, are they worth it? does the engine have to be removed? Judging by the extreme pain in the ass it was for me to change my spark plugs I guessing that's a yes.
    Give me some feedback, opinions, what do you guys think?
    Feb 2004
    Evansville, IN
    Quote Originally Posted by ericmalvarez View Post
    Worth it = yes.
    engine removal = yes.
    Worth it = yes.
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
    Moderator
    Jul 2003
    Maryland
    Are you stock? Mostly stock? Running a large turbo?
    Cams arent worth it.
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    depends on mods, but yes
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
    Aug 2002
    Virginia Beach, VA
    Depends. If you're going to give up AVCS then no, they're not....the AVCS system (especially in 06 and newer models) is so good that it's not worth sacrificing the torque just for a little bit up top. If you're going to get upgraded AVCS cams or don't have AVCS in the first place then yes, it is worth it to upgrade so long as you can get a turbo that will make the upgrade worth while (vf39 and the td04 are none such turbos).
    ~Tim
    Miami, Fl.
    Quote Originally Posted by Timdog1650 View Post
    ~Tim
    I was asking because I have an 04' Sti with all boltons possible and a reflash and looking for a few extra horses without having to change the turbo which is currently set at 19 psi.
    Moderator
    Jul 2003
    Maryland
    Turbo and fuel/tuning will probaly yeild better gains for the dollar/headache involved.
    Moderator Donkey's Avatar
    Da boonies,Va
    Worthless without head work....
    2002 FORESTER S
    1998 FORESTER S
