a couple exhaust questions for you guys!
Results 1 to 15 of 29
This is a discussion on a couple exhaust questions for you guys! within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; hey guys i just got an 06 wrx and i love it its an amazing car!! but i would like ...
    Registered User Lbleiweiss's Avatar
    Barrington, IL
    hey guys i just got an 06 wrx and i love it its an amazing car!! but i would like to put an exhaust on it and go stage 2 so i was thinking about gettin a turbo back b/c i read on cobbs website that u need a turbo back for stage 2 and u also get added gains but i read on here that you can also go stage 2 with a downpipe and a catback id really like the sound of a catback with the performance of stage 2 but what about those extra gains from the turbo back? whats the difference between the two? will i still get the same stage2 output with a dp and a catback as i would with a full turboback system? thanks guys!
    ps. does anyone know where i can get the "sti genome exhaust"(like the one in the exhaust video clip thread) or just an sti exhaust if it will fit on the wrx?
    Blob-Eye Syndicate #121 MY04 Stage 1 WRB STi
    Dirty Crew #89 like it dirty? Dirty Thread!
    "0-60 Faster Than Your First Sexual Experience!"
    Gettin Sideways At El Mirage
    The Best Video YouTube's Ever Seen!
    Courtesy of SomeGuy 217 Productions
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    Turboback = downpipe + catback
    To be stage 2, you really just need an aftermarket downpipe, though most people replace the whole thing. A budget setup would be something like an HKS downpipe and the stock catback.
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
    Barrington, IL
    thanks teg! now please check out the ps.!
    Registered User psychobooe's Avatar
    Mar 2004
    USAF
    I would also be interested in an STI Genome exhaust. I love the way it sounds in the clips that I've heard, but I've never seen one for sale anywhere.
    Try not, do or do not. There is no try. - Yoda
    Mods
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    Quote Originally Posted by psychobooe View Post
    Subaru sells it, just call up the parts department and order, but it is $$$
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
    Nov 2005
    Central Florida
    Quote Originally Posted by bcyb1029 View Post
    is it a 3" exhaust ?
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Feb 2006
    Chicago
    it tappers to 2.5 to fit stock dp, its the same as the SPt with a can style muffler on the end.
    Barrington, IL
    so i cant use it with an aftermarket dp?
    Feb 2006
    Chicago
    You can, you just need the dp to tapper to 2.5in. cobbs dp does that.
    Barrington, IL
    but wont i get much more flow through a larger one?
    Oct 2007
    you should get the SR*S full catback exhaust + SR*S bell mouth downpipe
    you should get the SR*S full catback exhaust + SR*S bell mouth downpipe ,with no taper down ,all the way 3 inches ,here is the link to the review and sound clips::
    SR*S Catback Exhaust from EBAY PICS and VIDS
    http://youtube.com/watch?v=TaZ0XrDi4kM
    http://youtube.com/watch?v=awyFJvgBipw
    Barrington, IL
    that seems like an amazing exhaust thank you for the suggestion! can u tell me a few things though? if i get the dp first will it bolt up to the stock cat back exhaust? i want a dp w/ a high flow cat does the srs have that? if it doesn't what is a good dp i could get that would fit with the srs catback that does have a high flow cat? in this link on ebay does what pipes does this come with im no exhaust expert lol
    http://cgi.ebay.com/ebaymotors/SRS-C...QQcmdZViewItem
    Oct 2007
    SR*S doesn't make downpipe with high-flow cat ,because those high flow cat downpipe are useless and pointless ,they are not the actual cat-converter ,they are just a resonator and claim they are high flow cat ,so srs only make downpipe with cat-less , the link u show comes with a full catback exhaust only because catback means from the cat to the back, ,if you want a downpipe ,here is the link for it:
    http://cgi.ebay.com/ebaymotors/SR-S-...QQcmdZViewItem
    this downpipe is cat-less ,straight through with 4 inches bell mouth open and 3 inches pipe ,this downpipe will direct bolt on to your turbo and then bolt on to the catback exhaust ,then you will have a full turbo back with no restriction and get all the power you can get from your engine.
    Oct 2007
    and also there is no reason for you to use a 2.5" taper down exhaust when you are doing turbo back , the only situation you will need those 2.5" taper down exhaust is when you planing to keep your down pipe stock forever on your car ,because the purpose of using a taper down exhaust is to bolt on to stock down pipe with no air leak out ,so if you planing to do turbo back ,the SR*S Full catback exhaust and the SR*S bell mouth down pipe would be your best choice ,because they are all the way 3 inches with no taper down on any portion of the exhaust and down pipe.
    Barrington, IL
    kk thanks! but i wanted the high flow cat for emissions and boost creep im assuming a catless dp wouldn't pass emissions lol
