Page 1 of 3 123 LastLast
Results 1 to 15 of 41
This is a discussion on Stage 3 WRX vs. STI within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I have a 2006 WRX 5MT, it is currently stage 2. I have purchased a VF39 turbo, some 2004 STi ...
    Registered User INFARED's Avatar
    May 2006
    Freehold, New Jersey
    Stage 3 WRX vs. STI
    I have a 2006 WRX 5MT, it is currently stage 2. I have purchased a VF39 turbo, some 2004 STi injectors, I will be buying a TMIC and Walbro Fuel Pump.
    I have heard that the spoolage on the stock WRX is alot faster than the STI, at what RPM's will the turbo kick in? and is a Cobb tunned, or pro tunned WRX faster than a stock STI?
    Possibly just a dumb question but Im curious.
    INFaRED"06" WRX STage 2
    Perrin Catless UP,Invidia Catted DP,
    COBB AP,Greedy EVO2
    Hawk-Eye Alliance #77"Where 06 & 07 Unite"
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by INFARED View Post
    First off you wasted the money on injectors. 2006 WRX came with blue tops rated at 565cc.
    Second if you swap in a VF39 and tune it you will essentially have an sti with a 5MT.
    If you run a Cobb Stage 2 Vf39 map, you will have a stage 2 Sti.
    So what you are calling a Stage3 WRX = Stage 2 STI
    May 2006
    Thanks for the info, i knew i really didnt need the injectors. Only paid a few bucks for them, i can post the for sale later anyways. But thanks for the info.
    COBB AP,Greedy EVO2
    Registered User Robert46123's Avatar
    Jul 2006
    You'll actually have a bit more HP than a Stage 2 STI because the WRX heads are higher compression. Get a ProTune on a VF-39 '06 WRX, and you'll walk OTS Mapped Stage 2 STIs in a straight line.
    2006 WRX WRB Wagon
    Stage 2 Cobb catless DP and Borla Hush CBE
    *Total Loss*
    Jun 2006
    Nor Cal
    Quote Originally Posted by Robert46123 View Post
    Thats because if:
    OTS STG3 WRX = OTS STG2 STi
    Then
    Protune STG3 WRX > OTS STG2 STi
    Thats simple math and a no brainer. Anything protuned will always beat OTS like for like.
    The question is:
    Does Protune STG 3 WRX = Protune STG2 STi??
    Registered User CAllen11's Avatar
    Feb 2007
    The pinks don't flow as well as your stock injectors should of left em in......
    Jul 2006
    Quote Originally Posted by 06wrx4me View Post
    Thats because if:
    Then
    The question is:
    With the higher compression on the WRX I'd say yes. My comparison may be a no brainer, but it's more in line with reality. How many people run out and spend $400 on a ProTune for a Stage 2 setup STI or WRX? Not that many. However, getting a ProTune for a WRX VF-39 setup is a "no brainer" and most people will go that route. I've seen several poeple put down over 300 WHP and gobs more torque than any Stage 2 STI with a ProTune or otherwise with just a VF-39, TBE and STI TMIC on '06s with a ProTune.
    2006 WRX WRB Wagon
    *Total Loss*
    Moderator
    Jul 2003
    Maryland
    Thats because if:
    Then
    The question is:
    Then you have to factor in launch, gearing, and a few other variables.
    Over on IWSTI and Nasioc it's VERY common to have ProTuned stage2 STI's. The torque the 07's are making is pretty decent considering you arent losing time shifting into 2nd. There has been some very low 12's with 07 STI's.
    I think a vf39 wrx would have a hard time doing that. The heads dont flow well, the IC isnt as good, and the tranny/drivetrain wont put up with as much abuse.
    But of course this is magazine racing to it's fullest.
    Jun 2006
    Nor Cal
    Quote Originally Posted by 302@12psi View Post
    If I ever get me a VF39 or VF43, I already have an STI TMIC, A TBE, and a AP V2. Well have to seee cause Ill dyno protunne and OTS stage 2
    May 2006
    Im almost there, i have the turbo, now im looking for a TMIC, and fuel pump. Im still debating wether to go TIMC or FMIC, dont have that much money. Was considering SSAC since ive heard good things about it. But was wondering if its possible to put on the front mount, and load COBBS Map until i can get a protune. Cause driving from Jersey to Conneticut, or Maryland is a hike.
    COBB AP,Greedy EVO2
    Registered User farBeyondDriven's Avatar
    Sep 2006
    West Deptford, NJ
    +1, the '07 STI is a whole other beast. Plus, you must consider the undeniable weakness of the 5MT. I'll never even go Stage 2 on the 2.5L because my car needs to last.
    2006 Panty Dropper
    "I want to die peacefully in my sleep, like my grandfather. Not screaming in terror like his passengers."
    Jun 2006
    Nor Cal
    Quote Originally Posted by farBeyondDriven View Post
    Meh I'm stage 2 and have been for 15k miles-ish. Been to the track for 7-10 launched 1320 runs and no issues with the tranny. I was paranoid, but everytime I think its making noise I just tighten my shift knob.
    Registered User independent 68's Avatar
    Jul 2007
    Parker, Co
    this is seriously the most interesting and informative thread ive read in a while. solid technical info on here, and im lovin it
    "Whatever it takes"
    Sep 2006
    West Deptford, NJ
    I get your point but I'm going to need a little more than 15k reliable miles out of my car if I go Stage 2. The most anyone has gone (on an '06 @ Stage 2) that I know of is 25k.
    2006 Panty Dropper
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    I would have to stand by this. It will be close, but all things being considerd, the edge would still go to the stage 2 STi. I would predict the STi gets out of the whole quicker and the WRX would almost catch it at the finish line. Driver's being equal of course.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
