P0546 caused by gas brand?
Results 1 to 6 of 6
This is a discussion on P0546 caused by gas brand? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I have been using Chevron since I bought my car in 2002, but my boss just gave me the company ...
    Registered User Prince Ali's Avatar
    May 2002
    Southern California
    I have been using Chevron since I bought my car in 2002, but my boss just gave me the company Arco gas card to use. I have been using Arco for the past month and now my car is throwing the P0546 code. Is this a coincident or is Arco causing this problem? The EGT is fine according to my gauge.
    Thanks,
    Ali
    Thanks,
    Ali
    Administrator
    May 2003
    Do you have a gutted uppipe?
    May 2002
    Southern California
    I have an MRT catless up-pipe, but that was installed years ago.
    Thanks,
    Ali
  5. #4
    May 2002
    Southern California
    I don't think so. I have the VF34, sti injectors, MRT exhaust, up-pipe, and ecutek tuning. The tuning, vf34, and sti injectors were done last year. I don' t have the 2.2 resistor in place, but this is the first time I have gotten this code.
    Thanks,
    Ali
  6. #5
    Administrator
    May 2003
    Quote Originally Posted by Prince Ali
    I'm not sure if the Ecutek reflash supresses this code. Odds are you need to install the resistor.
  7. #6
    Feb 2004
    Evansville, IN
    Thanks,
    Ali
    thats an aftermarket EGT...the code is for the stock EGT....it has failed remove it, plug it & do the 2.2k ohm fix....problem solved...
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
