P0102 and P0113 after UP/TBE install
Results 1 to 3 of 3
This is a discussion on P0102 and P0113 after UP/TBE install within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I got my STi up-pipe and TurboXS Stealthback with hi flow cat installed and as soon as I fired up ...
    Oct 2004
    I got my STi up-pipe and TurboXS Stealthback with hi flow cat installed and as soon as I fired up the car I got CEL codes P0102 and P0113. I did a search and they seem to be related to the MAF and intake, neither of which I touched when installing my UP and exhaust. Any idea what these could be about? I'm using AccessPort Stage 2 and it won't clear the codes. My only engine mods are the up-pipe, exhaust, and AccessPort.
    Also on an unrelated note is Stage 2 supposed to be more "jerky" or "touchy" with the throttle than Stage 1 or stock? For example I'm shifting the same way I always did when I was stock or had Stage 1 but now with Stage 2 the shifts feel much more rough (only when accelerating hard). Also if I'm hard on the throttle and then lift off even a little bit the car bucks. Is this normal?
    And finally a very unrelated question, does anyone know if the Cusco turbo heat shield uses the stock heat shield bracket? I forgot to put that thing back on and if I need to take my DP off to put on the heat shield I'll be a sad panda
    Thanks
    Oct 2004
    Nevermind I fixed it. I had forgotten to plug the MAF sensor back in
    For future reference if you get the codes P0102 and P0113 together then check your MAF sensor, it's probably unplugged.
    Mar 2003
    KC
    sounds to me like your airflow meter is unplugged
    aquamisted wagon
    12.4 @ 111
