Stock WRX torque and power curve
Results 1 to 14 of 14
This is a discussion on Stock WRX torque and power curve within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi, I have been searching for the torque and power curve of the stock WRX and i can't seems to ...
    Jun 2005
    Hi, I have been searching for the torque and power curve of the stock WRX and i can't seems to find one. Maybe someone can direct me to one.
    Second question. Does the north american WRX have active valve control system (AVCS)
    Thank for your help
    Feb 2004
    Evansville, IN
    Quote Originally Posted by okla7788
    negative, only the USDM STi...
    there are several stock dyno charts floating around on NASIOC.com
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
    Moderator
    Jul 2003
    Maryland
    Completly off topic.....I would like to see a Stage 2 dyno plot laid out against the soon to be released 06 one. I am guessing that SOA has this car performing simular to a stage 2 by the time you factor in new ratios and what not. I bet 0-60 times will be right around each other.
    Feb 2004
    Evansville, IN
    is any 100% sure that the '06 is going to be a 2.5L? I just can't believe it...
    1988 Celica Alltrac
    Moderator
    Jul 2003
    Maryland
    The Subura Online Serive Manual has the wrx and sti as 2.5. Every other "performance" car they make has the 2.5. The baja has a 2.5 xt...2.5. Legacy 2.5.....So why not just make all the US cars conform to one set of 2.5 emissions? It's logical (atleast logical enough to belive).
    It's been all but confirmed this is what they are doing....they have to toss us some kind of bone....would anyone buy that car with the 05 drivetrain in it?
    Registered User AwdTurboWrx's Avatar
    Mar 2004
    Sun Valley,CA
    that compares stage 1 wrx and stock sti so it should pretty much give you your answer.
    btw 06 will have 2.5 and its gonna have 230 hp instead of 227 but torque is also around 230. It will probably be easier to launch and maybe get 1.8's stock (not possible with stock wrx) I bet a lot of people will just do low 14's a lot easier. Maybe some awesome driver doing 13.9-14.0. I doubt it will be anything near a stage 2. Turbo is supposedly the same so it will probably have basically no lag and a lot of top end to be desired.
    The Ghosts of Zooph and Sarcasmo Will haunt CLUBWRX forever!!!
    Feb 2004
    Evansville, IN
    Quote Originally Posted by 302@12psi
    it is logical enough to believe, but am I mistaken that the '06 USDM 2.5L WRX could no longer be WRC? criteria = 2.0L displacement maximim, AWD...production car...I don't keep upto date with the WRC but I thought these were the rules..last time I checked...
    hopefully they'll upgrade the tranny or at least the final drive like the LGT, BXT, FXT....
    if I were going to do it again I'd have a Legacy GT....Luxo Sleeper..
    1988 Celica Alltrac
    Moderator
    Jul 2003
    Maryland
    The rally thing is so overrated......you just have to have a 2.0 motor....between Japan and the UK this is an easy requirment to fill. Alot of the players in rally dont even produce a turbo version of there motor in production cars....the 2.0 is not enough to prevent SOA from using it in there car.
    Mar 2002
    Calmer than you are
    Quote Originally Posted by testes1010
    Correct. the USDM will no longer be anything like the WRC car. The JDM/EDM version will be though.
    go f*** yourself
    Oct 2003
    keep in mind that the 06 WRX pretty much has the engine/drivetrain combo of the Forester XT, and that thing pulls 13.8 stock. of course, the Legacy, with 250hp, is slower?
    embattled, we prevail...only victory exhaled.
    Jan 2004
    Rosedale, IN
    Here you go:
    This was a stock mode real time map laid over a stage 1 base map for a "stock" dyno run.
    Keith
    Miss the wifes WRX, but love my Ralliart!
    Jan 2004
    Rosedale, IN
    Here is after I switched over to a stage 1 real time map.
    On the stock mode map I was making 13 psi.... on stage 1 I made 14 psi. The peak power is only 12 wheel HP higher, but at 7,000 RPM the stage 1 map is a full 35 wheel HP higher than the stock dyno sheet.
    Keith
    Jun 2013
    Quote Originally Posted by Fourdoor View Post
    Here you go:
    Keith
    So this purely stock WRX ? Is it 2005 model ?
    Jan 2012
    Philly Area
    Quote Originally Posted by dzid_ View Post
    At the latest, as the last post was from 2005.
    - Will
