sub question
Results 1 to 4 of 4
This is a discussion on sub question within the Electronics/Car Audio forums, part of the Interior Mods category; my subwoofer did not come with the little "ring" that goes between the woofer and the enclosure to make it ...
    Registered User Dudley Dawson's Avatar
    Feb 2003
    sub question
    my subwoofer did not come with the little "ring" that goes between the woofer and the enclosure to make it air tight. what should i use as a replacement? rubber, silicone, ...etc. when my bass hits, i get a little "buzz". it's like a tiny vibration but it distorts the bass sound. i took out the sub and played it out of the enclosure and it sounds fine. so it must be a little space between the woofer and the enclosure when it is mounted in the bass tube.
    If the driver is a popular model you can order a ring specifically for it; you might try Madisound or some place like that.
    You can also cut your own with rubber or even cork. Think of it as a simple gasket.
    You can use silicone to seal it up but it'll likely be messy and smelly.
    Jul 2004
    go pick up a roll of adhesive foam weatherseal from home depot. It's a flexible foam strip about 3/8-5/8" wide. Just stick it around the hole, and put the sub on top. It will compress as you screw it in and form a nice, tight seal.
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    what he said ^ ^ ^ ^
