I don't know if I'm a guru but here's my take on things. First i wouldn't worry too much about the rear coax speakers as they are just for rear fill anyway. I would say bag them all together, but if you want them they certainly do not need to be amped. Second, as far as the components go, its all a matter of preference. Listen to a couple different sets of speakers, which ever you like the best then get those. As long as you do not abuse them they will be fine. Now I don't know how many watts per channel your amp is running but if you use two channels for the components then you could bridge the remaining two to drive a sub (if you wanted one), but thats up to you. If not you could use those two channels to power the rear speakers, but be careful, because if you have them as loud as the fronts they will screw with your imaging. hope this helped at least a little bit
LinkBack URL
About LinkBacks
. Im looking at this line up from them:
