View Poll Results: just so...
Voters
11. You may not vote on this poll
  • Go for it! :thumbup
    3 27.27%
  • Redesign
    5 45.45%
  • Can't decide.
    3 27.27%
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on Sub Box Concept within the Electronics/Car Audio forums, part of the Interior Mods category; ha! ha! now that I look at it.. i know what you're talking about... yes, it's the impreza "i" I ...
    Registered User GotWRX03's Avatar
    Apr 2003
    USA
    yes, it's the impreza "i" I will try to do the full circle, too. I will have the full details/measurements of the box whenever I start making it.
    I like to build my own custom box because of all the aftermarkets that I've seen, they're all too bulky and doesn't fit right under the trunk, and way too expensive.
    for the skin, I will most likely use 'pleather' instead the traditional speaker box cloth.
    this is for a sedan.
    Quote Originally Posted by gusto
    is that a weiner or the impreza i?
    try and do the full circle if its the impreza i
    otherwise the concept is good and glad to see someone think before they actual start hacking away at wood.
    is this for a sedan or wagon?
  2. #17
    Apr 2003
    USA
    thanks man. not much here, too. school and work that's pretty much it.
    nah. never took industrial design. i start with basic sub design then modify it from there, angles, height, color, etc. the reason i chose red is because red and black together looks good.
    Quote Originally Posted by Chunks
    not much up in my life lately, heh.
    anyway, the only change I would suggest would be maybe color? Maybe changing the red to something else. Anyway good luck, it looks pretty kickass.
    Did you ever take an industrial design class or something? It looks pretty sharp.
  3. #18
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    I'm a little confused looking at your design. It seems like your trying to build a box for a single sub with 'wings'. Are you also going to put a port in the sub box (is that what the hole in the side is?). If that's the case, be careful with making random ports for sub boxes. They can make a good sub sound aweful. Good subs will come with directions for building boxes with proper ports... if your comes with that, follow it to the 'T'.
    I don't know why you would use fiberglass for this... it's all flat, straight surfaces and trying to do that in fiberglass would be 10x the work for nothing. Do yourself a favor and use mdf. regardless of what you use, getting those patterns to look nice is gonna take a lot of work! Also, getting vinyl (i think you're actually refering to vinyl when you say pleather... i could be wrong though. I've never seen anyone use pleather in a car!) inside the design that you cut out is going to be a nightmare. If you do decide to give it a shot, i would suggest heat formable vinyl as it's easy to shape around corners and curves...
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
  4. #19
    Apr 2003
    USA
    the box is design to hold two (2) subs, one on each side - either 8"s or 10"s. the middle part is inclined back about 45 degrees be the surface where the amp is mounted flat.
    yes, I will be using vinyl (black and red) most likely. I am more inclined to use MDF because I have experience boxes out of MDF - but I would like to learn how to use fiberglass, too.
    there's not going to be a hole in that middle brace. it will have a 2" gap between the top piece and the brace though.
    it's hard to visualize it if you're not actually looking at the box, but I have it all in my head
    thanks for the input.
    Quote Originally Posted by MidKnight
  5. #20
    Apr 2003
    USA
    see if this makes more sense?
  6. #21
    Apr 2003
    USA
    the inside brace
  7. #22
    Apr 2003
    USA
    i specifically designed the subs to point outwards, not inwards or straight.
  8. #23
    Oct 2002
    Bergen, NJ
    Now I see it!! hehe thanks for clearing that up...
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
