Dynamatting my car
Page 1 of 4 1234 LastLast
Results 1 to 15 of 50
This is a discussion on Dynamatting my car within the Electronics/Car Audio forums, part of the Interior Mods category; Hey, I'm about to install my sub and amp, and want to put dynamate in my car. Well, it's not ...
    Sep 2004
    Dynamatting my car
    Hey, I'm about to install my sub and amp, and want to put dynamate in my car. Well, it's not exactly dynamat, but its the same stuff, just about 9283742390721095629437$ cheaper, and basically the same quality.
    I was wondering a few things:
    Where do I need to dynamat?
    How do i remove my door panels so i can dynamate behind them?
    ur help is much appreciated. thanks
    '03 Aspen white rex
    -Infinity Kappa Perfect 12D VQ running on a MTX audio 420D.
    -Kicker SS components (6.5") running on a hifonics saturn a4000
    -60 sq. ft of edead v1.2se
    Sep 2004
    Rochester, MN
    a good install is on nabisco
    search for: CDT, Raammat, Ensolite install by Chewy-WRX
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    I hate to tell you this, but on a WRX, you'll need very little dynamat. The only places that actually rattle are, the wing (fixed by tightening the bolts), License plate (simply use double sided foam tape), but apply inside the front doors to help your front components. No need to go too crazy, as WRX's have horrible acoustic properties to begin with. You can only improve, but never make great. Knowing this will save you much agony, pain and lost time trying to eliminate road noise. I used a door kit for my entire vehicle, and it sounds awesome, ....OK, so I lied, it sounds all right. Not nearly as good as my 99 GMC Jimmy, but still better than most.
    I'm a Dynamat dealer. It should weigh heavily on anyone questioning the validity of this statement, as I should normally be trying to sell you my stuff, not persuade you to resist purchasing it.
    True, Dynamat is necessary for any high end system. But there are some cars that are just not well suited for SQ or SPL High Performance systems, such as WRX/STi. I'm only telling you to be prudent, spend your money wisely on things that will make a noticeable impact.
  5. #4
    Sep 2004
    Where would I buy some double-sided foam tape?
    I'm lookin for like 10' of it. Would Lowes have it?
    I guess I can just call up there tomorrow or something....too bad I can't drive now...I have a cast on :'( i miss driving soooooo much....i can't drive til next monday...
    neways....where culd i get some of that tape?
    '03 Aspen white rex
  6. #5
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    Home depot, Wal Mart, any major tool/equipment/hardware store.
  7. #6
    Registered User Crump's Avatar
    Sep 2004
    New York
    Well I still used some dynamat behind the speakers, because I feel that you get a better seal, vs metal on metal.
  8. #7
    Registered User cannibal869's Avatar
    Jun 2003
    Marina Del Rey, CA
    Quote Originally Posted by ej20fan
    I mostly agree with the above quote.. I just "damplified" my WRX - all 4 doors, the trunk, and some rubberized spray on the inside of the doors and in the trunk, and also underneath the rear seat. While there really isn't a HUGE difference, there is a definate lowering of road noise, which was my primary reason for doing it. The other interesting side effect was that bass was noticably increased - so much so that I had to actually turn down the bass on my headunit.
    As far as is it worth doing? I think yes, so long as you don't expect to get huge differences and as long as you don't spend too much money doing it. The next part that I would think of doing (again, more to decrease outside/ ambient noise than anything else) would be to do the engine bay. But that's for another day
    -C
  9. #8
    SMR
    SMR is offline
    Registered User SMR's Avatar
    May 2004
    Stamford, CT.
    Just a couple thoughts-
    Would sufficient dynamatting reduce ambient/engine noise enough to be worth the weight tradeoff?
    How about the increased road noise incurred from larger wheels/smaller tires/coilovers?
    Am i becoming an old man for thinking about civilizing a car that produces a symphony of automotive sound
    Discuss amongst yourselves.......
    Wow, just wow
  10. #9
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    Quote Originally Posted by SMR
    That's like asking what the meaning of life is, whether blondes are better than brunettes, Coke vs. Pepsi. How could you ever expect someone to answer that
    The answer will be different. To some, yes, others, no. In the end, it's to each his own.
  11. #10
    Registered User Rich10's Avatar
    Oct 2002
    Long Island
    Lets take this in order:
    Blonds are definately better than brunettes.
    Coke beats Pepsi (although Pepsi One is much better than Diet Coke).
    About 15lbs of Raamat with some closed cell foam (less than 0.5lb) will make a big difference in the quality and quantity of ambient noise that goes into the passenger compartment. By reducing vibrations in the door and body (Raamat) and absorbing other ambient sounds (closed cell foam), the engine sounds better, potholes are a thump rather than a clang, and the car sounds more like a BMW than a Hyundai.
    2002 WRX WRB
  12. #11
    SMR
    SMR is offline
    May 2004
    Stamford, CT.
    See, now thats a concise answer- thanks rich
    Wow, just wow
  13. #12
    Registered User sportwagon's Avatar
    Nov 2002
    Marblehead, MA
    Do your doors closing sound like...
    a tin can dropping to the ground? If they do.. and I know they do! Dynamat (or equivalent (I guess)) can add some much needed substance to your car! Not everyone wants substance... but, if you've ever owned a european car, or a luxury car, and you miss the quietness of it... dynamat is the answer... I have dynamated my car to an extreme, and I used primarily dynamat extreme, but it has made incredible differences in the quality of both my audio and a huge decrease of road noise. I own a wagon, so I can't say anything about the acoustics of a sedan, but the first thing I did for my audio system install was to dynamat the trunk! In doing so Iliterally noticed bass increasing from the POS stcok PAPER speakers as I furthered my progress with the dynamat! I was weary of the claimed properties of Dynamat, but I was sold as the bass appeared out of nowhere from my stock speakers. For a average, run of the mill system... don't go overboard! But when you're system is on the higher end... Dynamating gives the clean smooth sound you are looking for, and produces amazing bass! Seriously! AMAZING BASS! Plus it helps keep your car warmer in the winter and cooler in the summer (if AC is on, obviously) because it not only stops sound transfers, but it also helps to minimize heat transfer, too! I SWEAR, I don't work for Dynamat, but I am A FIRM Believer of its capabilities! my 2 cents!
    -Sportwagon '02
  14. #13
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    Personally, I object to such frivolous addition of sound deadner. Yes I used Dynamat in crucial areas, but I didn't buy my car so that I could weigh it down with Dynamat. If anything, I've removed some of the sound deadner that my car came with, especially in the trunk. The question is what your values are. Good sound NEEDS/REQUIRES dynamat, but also NEEDS/REQUIRES your car to be a good acoustical candidate (WRX's need not apply here). Excellent examples are European cars (not all) higher end luxury sedans, and unfortunately the ever dreaded SUV and station wagon. I'm not knocking on anyone....seriously, this is all in good fun and for the gander of this discussion.
    Yes, your car can sound better, the decision is yours. Don't expect it to sound like your buddies S class, but it can and will sound better, even good, but with the side effect of added weight. In the end, after we've all passed the buck and filled the can with our 2 cents, the decision is yours, as everyone will likely take a different path. You know best what you want. But please don't tell me that you'll add Dynamat, only to go out, buy a set of headers, RFL BOV, a 3" turbo back exhaust, 18" rims with lo-pro tires that have contact patches the size of Oprah's Mumu, as such completely lays waste to any sound deadening you were going for.
  15. #14
    SMR
    SMR is offline
    May 2004
    Stamford, CT.
    Very well put-
    Wow, just wow
  16. #15
    Sep 2004
    hahahaha so true
    '03 Aspen white rex
