Results 1 to 9 of 9
This is a discussion on Running amp wires to my trunk within the Electronics/Car Audio forums, part of the Interior Mods category; starting to run RCAs, speaker and power wire for my amp in the trunk. does anyone know how to get ...
    Registered User jimmy04wrx's Avatar
    Jul 2004
    San Jose, CA
    starting to run RCAs, speaker and power wire for my amp in the trunk. does anyone know how to get it pass the back seat without messing up my car?
    lightly modded with a hint of audiophile
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    Take out the back seat cushion(the one you sit on). Unbolt the 4 bolts that hold the back seat back, lift it up a bit, and feed the wires underneath where the arm rest comes out of the back seat. Bot everything back up nice and snug when you are done. Then you are GOLDEN.
    I did the same thing with my MTX amp and Bazooka subwoofer in my car.
    Jul 2004
    San Jose, CA
    ditto
    Mar 2002
    San Jose, CA
    Originally posted by jimmy04wrx
    ditto
    huh?
    Jul 2004
    San Jose, CA
    haha that means thanks for the help and ill try that out.
    Registered User toxin's Avatar
    May 2004
    Kiev
    Does anyone have instructions or pictures, how to run the amp power wire from the battery through the motor shield?
    Registered User adizzle02's Avatar
    Mar 2008
    Sandy Utah
    Quote Originally Posted by toxin View Post
    there should be a rubber gromet on the driver side by the clutch. you can run it through there
    VF39'd and Clark Tuned
    BugEyeMafia #176
    Basshead Member #3
    Registered User 321wings's Avatar
    Jul 2008
    It's really easy, run it through the grommet, down the driver side door sill, under the rear seat and into the trunk. I put the stereo in mine.
    Nov 2005
    Bay Area, CA
    YouTube - Episode 1: Subaru WRX: Running an amp power wire, part 1
    YouTube - Episode 2: Subaru WRX: Running an amp power wire, part 2
    2011 VW GTI - K04
