help my sub doesn't make any bass
Results 1 to 7 of 7
This is a discussion on help my sub doesn't make any bass within the Electronics/Car Audio forums, part of the Interior Mods category; Perhaps someone can help me diagnose the problem? I can hear my sub playing music but it doesn't make any ...
    Jul 2003
    KC, MO
    I can hear my sub playing music but it doesn't make any bass.
    My sub was working fine a few days ago.
    I've tried:
    1) the fuse is not blown
    2) the amp is receiving power
    3) swapped to another amp and no bass still
    My setup is stock HU to Line out convertor to amp to sub.
    I am guessing either
    1) sub is broken
    2) line out convertor is broken
    what do you guys think?
    thanks!
    04 WRX Black no options!
    Helix up/downpipe, HKS catback & Bov, autometer gauges and MRT shortshifter, Bronze Rota SDRs, UTEC, tein SS coilovers, HKS type1 turbo timer, 6000K HIDs, JDM spec C front/rear lips, 20% tint
    to be installed: Mines Spoiler
    Registered User hybrid gti 2's Avatar
    Apr 2004
    lancaster
    check wire from head to sub.
    Jul 2003
    KC, MO
    so if this wire got loose the sub will still play music but with no bass?
    Hudson, OH
    Here is what I would check. Make sure you have positive to positive from amp to sub otherwise if it is switched the sub will pull in when it should be punching out. Also, if that doesnt work try looking in the box and making sure all the wires go from box to sub correctly. Just things to check. The first thing i suggested happened to me, no bass, but i dont think music was still coming out.
    May 2003
    Wisconsin
    Hook up a 9V battery to the sub and make sure it moves in some direction. Then check the connection to the amp and the head unit
    - F r a n z
    Bucky with teh lime powah!
    May 2003
    Knoxville TN
    what kind of sub setup? LOC suck. i ran one off my stock deck to my infinity basslink. had to have the gain up WAY high on the basslink, causing it to cut out and perform like you are having now. Check the voltage to the pos term on your amp while its doing this. if its not 12-14V check your power source and ground...
    i replaced the fuse holder in my system and changed to an aftermarket deck, NO more problems.
    MOTORSPORT-the only sport!
    Everything else is just a game...
    Banned highwaymrdr's Avatar
    May 2004
    midatlantic
    make sure ur headunit knows theres a sub there and turn it up
