Results 1 to 5 of 5
This is a discussion on Poping noises from my sub. within the Electronics/Car Audio forums, part of the Interior Mods category; My sub (Kappa Perfect 10DVC) has been making LOUD Poping noises (even w/ sound turned all the way down)... I've ...
    Dec 2002
    Cherry Hill NJ
    Question Poping noises from my sub.
    I've tried my old sub that was sitting around and does the same thing.
    I figured it's not w/ wire connections.
    Could this be my Amp(Alpine MRD-M300) or the subwoofer out-put on my headunit?
    May 2003
    Wisconsin
    Did you check for any cone or voice coil damage? My friend's Shocker sub-woofer starting making odd popping noises even at low volume before it finally died. How old are the subs?
    - F r a n z
    Bucky with teh lime powah!
    Dec 2002
    Cherry Hill NJ
    Ok, i think it's my amp...
    I have no RCA wires connected to reciever (so effectively no signal is being sent to my sub amp), but it still makes poping noises...
    It is my amp right?
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    Did you check your connections? A loose wire can make it pop, whether its the power supply to the amp or grounding or whatever.
    I would guess its your amp...when speakers fail they make LESS noise, not MORE
    Dec 2002
    Cherry Hill NJ
    I did check my wiring... But I'll doubt check..again
    I hope it's just something dumb that i'm over looking.
    I am probably gonna re run some of my wiring. I want to make everything neat, ya know, for peace of mind. Plus when I was doing installing everything, i was running low on wires, didnt do a perfect job... So mind as well take this oppitunity to make every perfect.
