subwoofer/amp problem
Results 1 to 5 of 5
This is a discussion on subwoofer/amp problem within the Electronics/Car Audio forums, part of the Interior Mods category; well, i own a pioneer 10" sub with a bazoka amp, it worked fine for about 15 months. the sub ...
    Registered User Dench's Avatar
    Feb 2006
    Medford, MA
    well, i own a pioneer 10" sub with a bazoka amp, it worked fine for about 15 months. the sub has a few cracks on it, all from impacts. Recently, all the sub does now is emit a continuois rumble, with varying amounts of bass coming out of it as soon as i plug it into the amp. I dont think the sub is blown, i have it on -5 on the bass control, and i dont listen to bassy music, maybe its the amp? im not sure, any help would be appreciated!
    New England F4
    Registered User wRxOne's Avatar
    May 2002
    Vallejo, CA
    check the wiring from the box to the sub. Also try putting another sub in your trunk to check if the amp is blown or not. I got this humming noise too when I had a JL W0, it was a blown sub though. Does your amp and sub match each other's requirements? Under powering a sub will cause more damage to a Sub than overpowering it.
    -alex
    Chuck Norris' tears cure cancer. Too bad he has never cried.
    Feb 2006
    Medford, MA
    well, im no expert. The person that installed it does it for a living, so i was under the impression that power and what not was correct. The wiring seems solid also.
    New England F4
    Registered User kusan_31's Avatar
    Dec 2004
    Hilo, Hawaii
    check the grounding on the amp. if you're just connecting the sub to the amp (powered on without music) and it immediately rumbles, odds are that something is wrong with that amp. i dont think you're clipping the amp, unless the gain on it is all the way up.
    if you are already playing music and its rumbling, my guesses would be:
    the rumbling could be from the cracks to rub rub during the resonances or since it has been impacted a lot, the magnet gap possibly became misaligned.
    Mar 2006
    My mtx amp did that same thing. I truned down the boost control all the way down and took it off. Then I play with the control on the amp olny. The gain on mind is about half way.
