Higher output Alternators
Results 1 to 7 of 7
This is a discussion on Higher output Alternators within the Electronics/Car Audio forums, part of the Interior Mods category; Hey all. Just finished (well almost still painting the shroud that's holding my nexus 7) a custome install on my ...
    Jul 2014
    Hey all. Just finished (well almost still painting the shroud that's holding my nexus 7) a custome install on my 2012 wrx 5door noticed my head lights dimming not thrilled. I have an extra battery installed under the sub box (sub's amps are in a customer box where the spare tire was so keep all my trunk space) the fix for this issue in my truck that I traded in for this car was a higher output alternator. This being my first Subaru I have no idea what can be done I searched the forums and found a couple links but the newest I could find was a 140 amp for a 2010 does anyone know the output on the stock one and if the 2010 is the same as the 12 so it'll bolt right in? Or does anyone have any other links for the parts or ideas any input would be awesome
    Thanks in advance
    Dom
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Jul 2014
    I did not replace the alternator to battery cable the other two yes. Guess I can replace that first and see if that fixes it. But more info in the mean time couldn't hurt
            MainFrame's Avatar
    Austin, TX
    I run a 160A alternator from Maniac Electric in my bugeye. It's a huge improvement over the OEM 75A (that actually put out more like 50A max). Not only is the voltage regulation super stable (and actually 14.5V since I put a diode in the sense wire), but it's more efficient since it uses the larger housing, and it will put out over 100A at idle.
    Jul 2014
    Good to hear. You mentioned its a larger housing, did it bolt right in or was some fab work required?
    Edit: also looked at their site only shows up to 2010 is it the same for the 12?
            MainFrame's Avatar
    Austin, TX
    Yeah, it's still an OEM Subaru housing.. from a Forester XT I believe. It bolts up just like stock.
    I would assume the 2012 is the same, but I've never looked. I'm sure google has that answer, or you could call Christian at Maniac Electric and talk to her, she is very knowledgeable about alternators.
    Jul 2014
    Awesome thanks I'll givim a call tomorrow thanks for the Info
