Easiest and least intrusive ways for stereo sound improvement on 2015 WRX Premium
Results 1 to 8 of 8
This is a discussion on Easiest and least intrusive ways for stereo sound improvement on 2015 WRX Premium within the Electronics/Car Audio forums, part of the Interior Mods category; Would someone advise me what is the easiest (bolt on, least intrusive) and the least expensive way to upgrade default ...
    Registered User ebwrx's Avatar
    Jun 2014
    upgrade default speakers or even a stereo system on 2015 WRX?
    Thanks in advance.
    Jan 2012
    New Jersey
    Most likely you would want to upgrade the stereo. Subaru has been known to have bad clarion HU's
    CFLip2x 2012 WRB WRX Build
    Aug 2012
    South Glens Falls
    In my LE STI I replaced all door speakers with Polk DB6501 speakers. These are much better than stock.
    Like cflip2x said the next thing that would make a difference would be a head unit. Basically any of the quality aftermarket head units are going to power the speakers much better than the stock unit could.
            MainFrame's Avatar
    Austin, TX
    I would replace the head unit, then if it still doesn't sound up to par, replace the front door speakers, and go from there. I wouldn't consider either of those mods intrusive at all.
    May 2014
    just keep working down the list until you are satisfied
    Head Unit
    Front speakers / tweeters (component pref)
    rear speakers (coax is fine)
    add subs w/ 5ch amp
    Jul 2014
    Ottawa, ON
    Try this:
    Turn key on
    On the radio, press the 1 and 6 buttons and then, while holding those buttons down, press the Tune knob in twice. This toggles the 'Loud' setting.
    You can also change the overall radio config by pushing in on the Volume knob to turn the radio off, then hold the 1 and 2 buttons down while pressing the Tune knob in twice for Sedan mode. You can set it to Wagon mode by holding the 1 and 3 buttons down while pressing the Tune knob twice. Or, the preferred setting, hold the 1 and 4 buttons down while double tapping the Tune knob for Through mode.
    I Drink & I Know Things JaySin's Avatar
    Mar 2008
    Detroit Metro
    Quote Originally Posted by Kevin8se7en View Post
    Try this:
    Turn key on
    Is there a toggle for the optional upgraded stereo as well or just the stock one? I assume only the stock...?
    Jul 2014
    Ottawa, ON
    Quote Originally Posted by JaySin View Post
    I'm not sure but I think it's just for the stock HU
